Flying Illini
Hit me Peter!
- Mar 9, 2003
Flywrite said:I seem to remember FedEx Corporate being discussed on this board a while back. Try a search, I think you'll find some good info.
Also saw two GLEX's that are DHC08 and DHC2 that belong to De Havilland Inc. I didn't know they owned two of those.[/QUOTE said:DHC flight numbers are not De Havilland owned aircraft, but newly produced aircraft out on test flights. They could be DHC-8's or Globals or even Challengers.
Interesting. Why would a Bombardier aircraft operate a test flight under the De havilland callsign? That does explain why they both were listing their departure point as their arrival point as well.PMVULB AvMgr said:DHC flight numbers are not De Havilland owned aircraft, but newly produced aircraft out on test flights. They could be DHC-8's or Globals or even Challengers.
Flying Illini said:Interesting. Why would a Bombardier aircraft operate a test flight under the De havilland callsign? That does explain why they both were listing their departure point as their arrival point as well.
The data tag for the aircraft listed DHC08 as the callsign (replaced the tail #) and the other listed as DHC2. Both listed GLEX under the aicraft type.
Upon checking the properties, the tailnumber/callsign was listed as De Havilland Inc. which is why I thought they were De Havilland's aircraft.
