flywest
Respect my authoritaaahh!
- Dec 31, 2001
I am currently considering applying at ACC. After reading some past posts, I was wondering if any current ACC pilots (or former pilots) could answer some more questions I have.
Thanks,
FlyWest
- If you get hired, can you choose to do the "on call" (reserve) rotation?
- If you have an out and back run, do you spend the day at your hub (home), or at the outstation?
- When you are at the outstations, do you have a hotel or crew rest area?
- How much do captains make? (other posts said around $40k, is there a more exact number?)
- If you were assigned a base that you didn't initially want, can you transfer to another base if it comes open?
- Is there any per diem?
- I have approx. 2600 hrs with 400 turbine, 1200 multi; would I be considered for a captain postition, or as an FO initially?
Thanks,
FlyWest
