• NC Software is having a Black Friday Sale Event thru December 4th on Logbook Pro, APDL - Airline Pilot Logbook, Cirrus Elite Binders, and more. Use coupon code BF2020 at checkout to redeem 15% off your purchase. Click here to shop now.
mold/mildew smell removal blehhhh
I fLy pLaNeS
Living an Honest Life
Total Time
Enough
Aircraft sat outdoors for a month in which nearly every day it rained. Any tips how to get the smell out? Thanks!
avbug
Total Time
n/a
You can have the interior detailed and steam cleaned as best you can. If it's really bad, then you're looking at interior work, including replacement of some or all the material.
A bigger immediate issue is what you're going to do about the water which potentially damaged electronics, wiring, or caused corrosion (or continues to do so), which may have pooled in lower structural areas, which could freeze at altitude and cause control problems, etc.
If water got behind breaker panels or wire terminal ends or splices, you can anticipate electrical problems. Be prepared.
