Metro
Does any AMF pilots have a copy of the ops-spec on the net they can send to me?
Thanks for the help everyone.
I have an outline of the opspec manual somewhere on my laptop. I can dig it up. PM me your email address and ill forward it to you. not metro specific but helpful.
Pyle
Umm, I can't suggest you do this, but an easy way to get the AMF opspecs would be to take them from the airplane, copy them at the fbo, and then return them to the airplane. Also, I would strongly advise you know them if you're doing a check with marvelous. He's a good guy, but does expect you to know your stuff.
If you are indeed going to training, you need to talk to your ACP about getting the training materials. I doubt anybody is going to cough up their SOP. They may not give them to you if you don't have a firm class date yet, but it can't hurt to ask.
Help
Anyone know the definiton of "heavy Turboprop"? My company is allowing 500hrs less total jet time, for upgrade to the left seat, if you have 500hrs of heavy turbo prop. I can't find it.
Congrats and enjoy it. The tube is a fun and rewarding airplane to fly. Don't let Buff razz you too much either. Someone recently decided to let him fly again and he was seen trying to taxi the tug out before someone reminded him what an airplane looked like.
Some nice numbers for the tube:
1. In the sim 4 degrees pitch up is your magic number. When in doubt and throughout your manuevers return the 4 degrees for level flight. Not so in the real thing. 1-2 degrees nose up in real life.
2. To set your airspeed subtract 100 kts from the desired airspeed and divide by 2. That will give you a target TQ setting. For example, if you desire 240kts then -100 = 140/2 = 70 TQ. Kinda cumbersome at first, but works well when you get used to it.
3. For constant airspeed descents subtract 10% TQ per side for every 500 fpm you wish to descend. So if you're doing 200 kts (50 TQ) and desire a 1000 fpm descent then 30 TQ per side will work nicely.
4. Between FL 180-210 is your cruise sweet spot at 610 EGT and 97 % rpm. You can take it higher, but are losing out if you aren't running speeds high.
5. For loading: 800 lbs or less put it all in bay 4 or 5(expediter). 800-2000 lbs put it in bays 2-3 or 3-4(expediter). Any heavier than that and you need to start in bay 1.
6. To set your pressurization divide your altitude by three and set that for your cabin altitude. You can work from there.
7. If your nosewheel steering is deferred try taxiing speeds high. It makes a huge difference.
There's a lot more to it, but that's all I can think of off the top of my head. Maybe some other deathpencil drivers can chime in with other good advice.
They probably mean turboprop over 20-25,000 lbs. I have no actual definition for you.
CVG based... hahahaha
Okay, I was only TDY out there, but they do like to make you work your shift. Hopefully, they will be going onto, or have already gone onto a 3 on 1 off sched. I made the mistake of asking if I would be getting the weekend off, I was laughed at, and the joke was retold several times to all the pilots.
But there are plusses, of course (I'm not really a negative type of guy). You will get lots of flight time during your stay. Also, my buddy is based there and I've heard he's moving into the Emb120. He was there for 3 months after moving into the Metro. And another upside, in my 15 days of TDY, CVG and PIT were the only airports I landed at more than once.
In CVG all the metros are heavy, and one is extra heavy, meaning they've reinforced the flooring so it can take a higher lbs/sq foot loading. Oh... another plus, the loading is usually palletized so it is SOOOO easy to load. Just don't drop the thing on its tail (my first metro with a tail stand!!! wooohooo. I thought I was done with that, but there it was).
I'm sure that you've already done the research and know all of this though, so I'm just wasting my time. Have fun, it's a great airplane and all the guys at CVG are good.
On the shelf
Flyin Tony:
Do you know when you will be doing your next tail swap? I can have a bunch of stuff waiting for you at the hangar. All I ask is that when you get your own stuff you return it to me because I will need my books again to hopefully help AMF with some future projects.
Send me a PM or arrange it with Joblio he can hook you up!
Have fun in the Metro... it is a great experience!
DR
