pgcfii2002
"Uh....oh yeah...&quo
- Jul 20, 2003
While I understand your point, that the authorized instructor must be rated in the category and class when he is providing the flight training required in 61.56 Flight Review, he does not necessarily have to be PIC, unless the applicant has allowed his Flight Review to expire, and is no longer able to be PIC.While administering a Bi-ennial, are you the PIC?
But on a flight review, I log the time as pilot in command, not dual received.
The only entry made by the instructor is the bi-ennial endorsement in the logbook.
And the hour long flight is about twice the amount of time needed to perform the flight. I usually end up flying around sight seeing after the maneuvers have been demonstrated to get the required time to satisfy the regs.
If that's your mindset, Sir, no worthwhile instructor will want to do anything for you.Anything longer simply pads the instructors wallet.
Again, if you are so full of yourself that no one can teach, polish, review, update, or simply share experiences with you, no professional will want to waste their time on you.I am an expert on my aircraft, and there is no way that an ordinary MEI would have the knowledge and experience on each aircraft that he may park his butt in for an hour every other year.
I can safely say "Been there, done that, got the T shirt".
As I posted in an earlier post, it is an instructional period, by regulation. "1 hour each of ground and flight training." It is a dual requirement.So what are you going to teach me on a flight review? Remember, this is a review, not an instruction period.
In spite of your "I know it all" attitude, you are exceptionally well qualified on this particular aircraft, and it is going to be hard to find a seasoned CFI who can actually do some worthwhile training, and I also agree that I usually don't like mandatory numbers for training. But in 99% of the cases, the 1 hour is not overly demanding.What I'm saying that the FAA made an error in making it mandatory to arbitrarily make a flight review to last an hour in the air. This should be at the discretion of the instructor, not a bureaucrat.
Since I restored the aircraft from two truckloads of component items, I have an intimate knowledge of my aircraft.
I also perform the annual inspections yearly on the bird.
This includes pumping the gear up and down using the hand pump. The engine driven pump is on the front engine. I cage the engine, and pump the gear down, at a safe altitude, periodically, then perform an airstart on the powerplant. The engine is equipped with unfeathering accumulators. The airstart procedure is different with them than without. Would you have known that? I am an expert on my aircraft, and there is no way that an ordinary MEI would have the knowledge and experience on each aircraft that he may park his butt in for an hour every other year.
Some individuals may take less time to demonstrate maneuvers on a flight review, some may require more time. What I'm saying that the FAA made an error in making it mandatory to arbitrarily make a flight review to last an hour in the air. This should be at the discretion of the instructor, not a bureaucrat.
What if they arbitrarily told me that I have to spend 20 hours performing an annual on your C-172?
The minimum is there precisely for pilots like yourself, who feel the rules do not apply to them.
You are not special...you are an accident waiting to happen.
Whatever you are, you are operating without a proper flight review.
...but you already knew that, right hero??
"Since I restored the aircraft from two truckloads of component items, I have an intimate knowledge of my aircraft...
I am an expert on my aircraft, and there is no way that an ordinary MEI would have the knowledge and experience on each aircraft that he may park his butt in for an hour every other year...
I can safely say "Been there, done that, got the T shirt"...
OK d1ckweed, you know nothing about me."
Oh!, I think we know plenty about you. I have to agree that with your stellar attitude (NOT!) you are an accident waiting to happen.
How about the next time you want a flight review you take a good look at yourself and when you talk to the instructor that is going to give you a BFR you ask him to teach you something you don't know. I know it's hard - you know everything right?
A good BFR is shaped for the student (<-yep, that's you) you probably don't need help with systems - but I bet you could cover some non-type specific stuff that maybe - perhaps - you might learn something.
Later
Hey A¢e,
That might be your interpertation, but that is also wrong. I get ramp checked every other weekend at airshows by the local FSDO's as a performer. These different inspectors have examined my flight log, and aircraft logs with no discrepancies.
Please explain why geographically seperate FAA offices have found this to be in compliance?
And I may be a "hero" to you, but I like to think of myself as an ordinary aviator. I appreciate the compliment though.
No you may go back to your pathetic instructors lounge and knaw on your popcicle.
You probably should you have a sign-off list to followWhat if they arbitrarily told me that I have to spend 20 hours performing an annual on your C-172
If a BFR is flight training and flight training requires appropriate category and class ratings on the CFI certificate, then the answer is "Yes". Another poster quoted that language from the reg and then inexplicably reached "No" as a conclusion.
Must be MEI.
This is a forum for regulation, and generally I try to confine my replies to the topic of legality. However, the above quoted statement is one of the most foolish and arrogant statements I've read on this site in some time.I've been flying this same airplane since 1989, have over 700 hours in it. There is nothing that I have not seen in it.
When is the last time that you intentionally spun a multi engine airplane? Unusual attitudes, not an issue in a 337.
Tell me, why would it take any longer to do a flight review, every flight regieme can be covered? Single engine, short, soft field, full stall series to include accellerated stalls. Anything longer simply pads the instructors wallet. Plain and simple.
