satpak77 said:is it just me or as a PAX does it seem that all MD-80's land pretty darn hard, regardless of carrier?
or is it just the Fly Navy crews I have had lately?
enigma said:Obviously, you haven't flown with me
I ride in the back quite frequently as a commuter and on company deadheads. I'm usually on AA, and I can say that the AA Super80 crews do a real good job of landing the bird.
The -80 isn't easy to land, but doing so is possible. The location of the mains is significantly aft of the pitch rotation point, so a normal landing rotation actually drives the mains down. Once you learn to flare early, then PUSH over at about the point of touchdown, you'll roll it on every time. Unfortunately, even after thousands of hours in the airplane, it still takes a conscious effort to push when your reflexes want to pull.
enigma
Pilot877 said:That sounds a lot like the DC-10, too. If you flare too late, you drive the mains into the runway.
flx757 said:If you "fly" it on to the runway, it is very easy to get consistently good landings in the MD-80. I never subscribed to the "push" theory. I don't believe in it, I don't use it, I don't teach it. Good technique is all that is required. Don't over-rotate in the flare, know the pitch attitude required, flare just enough to break the descent, then hold it. It smoothly rolls on.
bobs98tlr said:No offense to the FedEx guys but i see that pretty frequently with them.
Pilot877 said:You're kidding, right? That's probably one of the finest group of aviators in the business. I'm sure they don't suck like that.
bobs98tlr said:I just said if you watch them land the DC-10's you'll see a lot of them drive the mains into the ground kinda hard.![]()
An LSO would tell you otherwise.bafanguy said:I will tell you that you can judge very little about the "quality" of a landing while watching from the sidelines.
Hugh Jorgan said:An LSO would tell you otherwise.
njcapt said:The MD-80's, especially the long body ones, land like crap. I had to utilize the push over technique to make anything approaching consistent landings. You've got to remember that you're using a little tab to move the whole elevator and when you're bleeding off speed carried for winds and gust factor, you can easily run out of elevator authority before the beast touches down. I used to trim back and hold forward control pressure when I had more than a ten knot speed additive to counteract this tendency, and I didn't appreciate having to pull shizzle like that to attempt to make a decent landing. In calm or low steady state wind you can get in the ballpark for a decent landing, but if you touch one of the mains down gently (I can't remember which one) the freakin spoilers deploy all at once and make the thing plop down like an old man getting into a lazy-boy. Bottom line, if you try to flare late you'll drive the mains into the ground.
