Jetdriver125
Member
- Jun 12, 2008
If the manufacturer states the SB to be mandatory then non-compliance would make the aircraft un-airworthy correct?
Essentially a mandatory SB and a AD have the same effect,
difference being one is issued by the manufacturer and the other by Aviation Authorities.
AVBUG is correct
If the aircraft is operated under 91.409(f)(3) for it's inspection program (which is an option that applies to large airplanes that are turbine powered and turbine powered rotorcraft) than a Mandatory SB issued by the manufacturer must be complied with.
