A reminder, especially on new aircraft. Retorquing, inspecting connections, etc. should be carefully checked at least at each annual/condition inspection. Thorough inspections are key to accident prevention. Take your time and inspect thoroughly. Put a screwdriver on screws, test other connections.
generalaviationnews.com
Loose Connection Leads To Crash — General Aviation News
Probable Cause: A total loss of engine power due to the loss of power to the electronic fuel injection and ignition system, which was the result of a loose connection between a common ground feed-through stud and the ground bus.
