SWA doesn't perform many ultra quick turns any more. I believe they fall mostly into the 20-25 minute turn category. Even so, that easily beats normal turns at other airlines. The biggest multiplier re pax carried is the turn time and GATE UTILIZATION, which also far exceeds most other carriers. Together they dramatically ramp up the number of flights they can operate and pax carried. Add to that their continual aircraft flow, rather than the hub and spoke with its large slack periods and SWA's.1.5 concourses will effectively be far larger.
Now figure in the number of international flights Delta operates, and the impact of SWA's schedule on Delta's remaining domestic system is likely to be dramatic.
It's a scenario that has been played out before.
As for a couple of dropped flights in Philly, I would hazard that it merely shows a case of market optimization. If SWA can dump a couple of unproductive routes and make more money with those assets elsewhere, then that's what they' ll do.
Might be those assets are headed to ATL.
