I can tell you it is not nearly as great as it sounds. And please don't think you can commute on reserve. It may work in the first day od so, but you're still going to need a crashpad or something. Trying to commute on it could get you screwed really quick! Good Luck!
Agreed. It seems everbody I talked to had different experiences on LC. But for the 2 months I did it, I wasn't too thrilled. It was good on the first day and last day, but the middle days could suck. Getting cut loose at 12pm instead of waiting till 1800 to go was great. Bidding R5 in IAH was almost better.
I commute, and I only got to spend ONE day at home.
And for the record, it's not so much a 12 hr callout as it is a 12 hr notification. Example, say you are flying in the middle of your reserve days, you block in at 17:45 with a duty off at 1800. Scheduling calls you at 17:55 and informs you of a 6 am show the the next day. They meet both the 12 hr notification AND the 11 hour domicile rest rule. Some guys think that you have to get your 11 hrs dom rest, and THEN 12 hrs to show time, giving you 23 hrs off. NOT THE CASE, READ THE CONTRACT. YOU ARE ON THE HOOK 24/7. Maybe some guys can go home and then commute in for a 6 am show, doubt it.
Don't forget, Long call gets used first. So if you are coming from days off, look at the open time. If all of it is am shows, you are not good for any of it since you can't show till noon. The sucky part is, they will give it out to all the guys that good for it. Guess what's left for the long call guy to do? ARC/airport ready.
