Yes, gliders count towards total time, as well as towards the requirements of additional certificates and ratings.Joshrk22 said:When you fly gliders does that add to your TT, and then contribute to powered time so you could actually get a Comm. in less time than 250 hours. i.e. 125 hours in a glider, 125 hours in powered = 250 TT = eligible for Comm?
§ 61.129 Aeronautical experience.
(a) For an airplane single-engine rating. Except as provided in paragraph (i) of this section, a person who applies for a commercial pilot certificate with an airplane category and single-engine class rating must log at least 250 hours of flight time as a pilot that consists of at least:
(1) 100 hours in powered aircraft, of which 50 hours must be in airplanes.
(2) 100 hours of pilot-in-command flight time, which includes at least -
(i) 50 hours in airplanes; and
(ii) 50 hours in cross-country flight of which at least 10 hours must be in airplanes.
redd said:If you log 125 hours in a glider and 125 hours in a single engine land airplane, how do you come up with less than 250 hours? Time is logged according to category and class; total time is a combination of all category/class times, and 125 hours plus 125 hours is 250 hours.
Commercial pilot certificate:
Of course, if you're going for the commercial under Part 141, then you can do it in considerably less than 250 hours; 120 hours of instruction under Part 141.
You seem to feel that flying a glider is somehow a lesser experience than flying a powered aircraft?
WateryGrave said:Plus it will make you a real pilot! I still contend that you are not a real pilot until you have flown gliders or taildraggers (preferrably both). I'll probably get vetoed on that one though.
Joshrk22 said:Anyone know how many a glider usually costs to rent? I want to do mine through CAP, anyone know how much the 2-32 costs (I know it's based on the wing; I'm in MIWG)? I'm doing my powered training through there now, so I want to do the 10 flight & 3 hours thing.
Gorilla said:One good thing is that if you soar enough cross country, you'll have real confidence in your ability to set up and execute a flame-out landing in a GA aircraft. Picking the field, setting up the pattern, glidepath control, slips, stuff like that.
