cougar6903
- Jul 2, 2002
If it's got an N-number, it counts as much as anything with a normal airworthiness certificate. If someone's going to hold it against you, then you're just as likely to experience bias from having time in a J-3, towing banners, CFI'ing, pipeline, or anything else.cougar6903 said:Anyone have any experiance on how 135 cargo and regional airlines view time in homebuilt single seat FW airplanes? The plane has a VFR panel with a rotex water cooled engine. Any info would be of great help.
GIVJoc said:Agreed
If it’s go an N number log it, just be sure to put experimental or homebuilt in the remarks section of you logbook.
GIV
