Logging Level D sim time
rod farva
How would you log a 4-eng turbine full motion, full vis sim? Would you log mutli-turbine, or just flight sim? Search function checked.
Thanks.
Also, is night time on NVG's loggable as night?
Level D sim time
Rod,
I log all my sim time under sim column, but not included in my totals. Officially the military counts sim time towards meeting min and totals. I used a blank column in my log book to log NVG vs "Un aided" night. I hope this helps.
A flight simulator, even the best of them, is not an aircraft, so you cannot log =any= form of "flight" time in them.
That "multi" column is a subcolumn of category and class of "aircraft" isn't it?
I have flow a ton of different sims, and that time has ONLY gone in the sim column. No where else. It's just sim time. That's it.
I log it under Sim, Simluated instrument, and approaches. Thats it.
Can anyone cite a reg for logging landings in a level D? I never log them because I can't find in the regs where it allows me to use it for currency. Also, where can someone reference information on what makes a sim level D. Is it just full motion?
I don't know about level D specifically, but you don't have to look any further than the currency regulation itself to find the simulator rule.
61.57(a)(3):
(3) The takeoffs and landings required by paragraph (a)(1) of this section may be accomplished in a flight simulator or flight training device that is -
(i) Approved by the Administrator for landings; and
(ii) Used in accordance with an approved course conducted by a training center certificated under part 142 of this chapter.
Thanks. Not sure how I missed that......
61.51(h) allows you to log "training time" in an aircraft, flight simulator, or flight training device. Furthermore, for meeting the requirements of the ATP, you can use up to 100 hours of simulator time (61.159(a)(5)) towards the 1,500 hour total time requirement.
So, why not log it? Clearly, you can log up to 100 hours of it as total time if you don't have an ATP. If you do, who cares anyway?
I don't think anyone suggested not logging it; just a discussion about where.
Clearly, sim time is "training time." But a lot of pilots reserve the training column in their logbook for training in an aircraft for convenience - they don't have to subtract all their sim entries when running an 8710 total.
Also, sim time is total "pilot" time, but =not= total "flight" time. Many logbooks call their "totals" column "total duration of 'flight'" and I think most pilots likewise reserve the column for "flight" time.
Want to do it different? No problem. Just makes sure your logbook is clear about what you are doing and do the proper math when 8710 time rolls around.
And equally important, when interview time rolls around.
I have around 50 hours of sim time in my total time. About 20 was using a PCAT to get my instrument rating and about 30 was level d going thru part 121 training. I have been to 4 different 121 interviews and was offered a job at 3 of them and no one has ever questioned anything about logging sim time. As a matter of fact no one has ever asked any question about logging ANY time.
I think you guys make way to big of a deal about logging time. Remember the old saying "Fly what you can, log what you need.".
I agree with B-J-J Fighter. People make a way bigger deal out of how thay log time. As long as you are not pencil whipping entries and have somewhat of a reason you will be fine. All of the interviews I have had amounted to a glance at the last two pages of my logbook, nothing more.
I think you guys are wrong on this. Where is avbug? Level D full motion sim I thought was considered an airplane. I had a FAA guy tell me this, but I never trust an FAA guy completely.
For everything you've always wanted to know about Flight Training Devices, Levels 1 through 7, see AC 120-45A, about 60 pages. For sims, Levels A through D, see AC 120-40B, and appendices thereto, in particular Appendix 1.
All are available at the FAA website by clicking the appropriate menu selections. As for logging, some of the sim training organizations state on their respective websites what is at least their understanding, and I think what I read on those sites was that the time is logged as sim time, but not as total time and not as airplane time. Hope the AC references are of some use. The AC info was my main reason for posting.
FAR 1.1
"Aircraft means a device that is used or intended to be used for flight in the air."
Do yourself a favor and log it as sim only. Eventually all airline apps will be electronic. Fedex, southwest, and several different airlines use airlineapps.com. These apps have you break out every freaking airplane type and at the end of the app your times are added up. If you included sim time your total time on the electronic app will not match your logbook.
pilotviolin said:
As in terms of logging time.
I know what you meant. You can connect the dots, or rather the definitions. If what you are logging is "flight" time, it must be done in an "aircraft."
In addition to the definition of "aircraft" checlk out the definitions of "flight time" and teh realted but different "pilot time."
Then look at 61.51 and see what it allows you to log.
I don't think so. Say you went to LR-35 initial and logged 24 hours of Lear 35 time in the Level C (or B or D, same difference) sim. Then you flew 100 hours in a Lear 35. You have now logged 124 hours of Lear 35 time.
When you then put your time into the electronic application, it will indeed match your logbook.
Personally, I think you should be able to log it. The regs don't say you can't (in fact they say you CAN), and if an employer wants you to exclude any sim time, they should say that on their application.
Actually, I think you need a C or D to do a sim-only type rating, at least according to Part 61, which references Part 142. Also, I believe that the ATP/type rating PTS provides a "task vs. simulation credit" chart, and that indicates a few maneuvers for which sim credit is given only in a C or D.
An applicant for an initial type rating who does not meet the requisite experience criteria (61.63, 61.157--for a sim-only, unrestricted type rating) and who obtains his/her rating in a (C or D) sim-only program will have a limitation on the type rating which will probably require 15-25 hours of supervised PIC in the airplane. In your hypothetical, say the newly rated pilot has his/her 24 hours of sim, with a limitation on the type rating (assuming pilot does not meet the experience requirements for unrestricted sim-only type rating), and then acquires the 25 airplane hours needed to remove the limitation. Does that person now have 49 hours "in the Lear 35"?
(the 24 hours in the sim, and the 25 hours in the airplane to remove the limitation on the type rating) Consider that had the type rating been accomplished in an airplane, not a sim, the same pilot's type rating would be unrestricted ab initio. And the restricted pilot may not simply log more sim time to remove the restriction.
This might be an area where there is some ambiguity, but I think the pilot in your 124 hour hypo has 24 hours sim (Lear 35 sim, if you prefer) and 100 hours "in a Lear 35". But, as I said, this area is not without some ambiguity.
I recall seeing some discussion of this (logging of sim time) on one of the sim school's websites, but can't find it now.
Incidentally, it is the practice of a couple of IGIs I know at an approved school (who are not CFIIs) to act as authorized instuctors within the meaning of the FARs when it comes to instrument currency time (and possibly other instrument dual, I don't know) in the school's FTD. Just thought I'd throw that out there. Kind of suggests (to me, anyway) that the time spent with these IGIs on the FTD is not "flight time". And, although this partcular FTD supposedly replicates a PA-31, most FTDs don't replicate a particular type. The original post was about Level D sim time. But note that most of the FAR references to logging (at least the ones cited earlier in this thread, e.g., 61.51) don't distinguish between FTD, sim, or between different levels, so type replication might not matter when it comes to logging as sim, flight, total time, etc.
Just wondering about who is responding here. Midlife and others; have you ever flown a level D sim? I got my type in one and crossed the airport with "no time" in the aircraft, and flew the acceptance flight on our new plane. Should I log the time? Think about it.
Nope. But I don't think you need to fly a level D sim or even a "real" 757 to understand the rules about how you log the time.
The discussion isn't about the quality of the Level D time or its equivalence to the "real" thing. We all know that it is. That's why, for example, the rules say that you may log simulator landings if the simulator certification says so. It's about a bunch of artificial FAA rules about what columns you are allowed write things in your logbook.
I have flown many, many hours in Level C and D sims. I have gotten several type ratings entirely in the simulator and have given numerous type ratings in them. Sim time is sim time. It is not "flight time". It is not the "same as an airplane" when it comes to logging the time.
jschroed, I beg to differ.....
I personally know of a pilot that had his ass handed to him at a Delta interview for logging sim time as flight time and trying to defend the practice during his interview. Needless to say, he did not get the job. Try to think of it this way. How much level D sim time can you have when you've got 1500 TT? 50 hours? 100 hours? How much when you've got 5000 TT? 300 hours? Do those sim numbers really make such a difference to your Total Time bottom line? So much of a difference that you'd get the job over someone with 300 hours less than you? We all log time for 2 reasons: currency and interviews (3 if you want to count pride). If a questionable practice of logging time (in the eyes of an interviewer) is discovered you can kiss the job goodbye....why take the chance?
I would only log Sim time if the sim was ripped from the ground during a tornado and was propelled into flight.
If you cant get violated doing it then you cant log it!
Thanks for the good insight. As I said before, I never trust an faa guy. I will ask FSI next month what they think.
Many of the insurance applications, and at least a few job applications I've seen refer to "Pilot Time" rather than "Flight Time." Per the regulations, wouldn't approved sim time count as "Pilot Time" even if it is not "Flight Time?"
