Line Bidding VS PBS
One you control yourself, the other you trust management to do it for you.
The pairings are construcyed by the company in both cases...PBS cannot fix crappy pairings.
PBS
- More likley that you will get a specific day off (unless it is Christmas)
- You may be able to get better commutability
- More lines, less reserves
- Allows senior folks to cherry-pick the best trips
- Often less days off for low/mid seniority lineholders
- No "common sense" applied to line construction
- If you do not understand how PBS works, you will be sitting hot reserve on Christmas day, regardless of seniority.
- If you are not computer-savvy, you are screwed.
Paper Bid
- Lines are often fairly consistent
- More reserve lines
- Low/Mid-seniority folks often get a better deal than with PBS, because the top dogs can't cherry-pick ALL of the best trips.
- If you need a specific day off, you may have to go below your normal seniority (and line quality) to get it.
- Dumbasses can use this system succesfully.
PBS is probably the better system, but it might hurt mid-seniority guys.
PBS seems to give a better balance within comparing senior to junior pilots. My experience is that some of the senior folks don't think to highly of it. My opinion is it works great if you know how to use it. There are a lot of tricks and ways you can screw yourself. It takes a lot of bidding periods to learn how to use it correctly. I love it though.
7777 nailed it. But, with PBS, your company scheduling can adjust parameters in the computer at will. I.E. running a bid, looking at the results, not liking them, changing things in program, re-run it, etc. over and over-until they get what they want. This can potentially screw up a good system...
Over all I like the flexibility of PBS over the line bid system.
B
NOTE: if you work for a company with a bunch of bases-PBS won't work as well as a company with few bases... MUST have a large base for the PBS system to work at it's best...
PBS
Paper Bid
Yea, what he said except vacation plays into this. Depends on the compant though. On PBS the line the company builds for you will work around the vacation but with a line you may be able to drop trips which conflict with your vacation.
Pbs Sucks!
PBS is hands down better! First of all you don't have to spend hours going through lines and pairings. It would take forever to shift through all the lines in the past. With PBS you have the chance to not have such a monotone schedule. You can work a combo of different trips instead of having to do the same trip every week. You get to meet a lot more crews since you don't fly with the same person all month.
You are on reserve a lot less under PBS. You get as much if not more days off than you did under the old system. Basically your senority gets you a lot more with PBS than it does with hard lines. Its a no brainer really. I spend about 30-40 minutes setting up my bid on PBS. its easy as pie. To go through all the hardlines can take a lot longer than that unless your quite senior.
For the most part you get to write your own line instead of bidding on one that is already made for you. You choose the credit, you choose what days off you want and usually you are able to get it too. Based on this its actually hardlines that suck! Hey I guess if you like living in a time warp doing the same trip over and over each month working with the same crews over and over then you might miss it.
Unless you're really senior, PBS is not likely to give you what you want. That said, regular lines mostly don't either. Truly, it won't affect me, but if I were junior, I'd rather seen the crappy line I was going to get (defensive bid) than wait until it was all over.
My issue with PBS is that it's like every pilot is on a relief (buildup) line. They will backfill your vacation and minimize your days off. Right now at ASA, we can turn 7 says of vacation into 14 days off by bidding right.
PBS is an efficiency and productivity tool for management. Pure and simple. That is the reason it was created. If you don't have it now, bringing it in is a concession.
What are you smoking? Going through pairings in line packets killed time flying. Now I have to spend time more time on the computer to no avail. You were at least guaranteed to get a set schedule THAT YOUR SENIORITY COULD HOLD. PBS, I can't hold anything that I was. 2 day trips are a dream now. Weekends off or weekend day), no chance even with crappy trips. Trying to get one day off for a wedding or something... don't bid for it because it's the last thing you'll get. Death to PBS. I'd say 30% of people like PBS and they're all really senior. There are a few junior people that like it but they don't know any better or weren't around long enough to get a good schedule. Seniority means JACK with PBS.
How are you not getting 2 day trips? How long have you been here? I am getting 2 or 3 day trips regularly. I also get weekends off, most days off that I bid and around 15-16 days off a month with about 85-90 hrs credit. Pick up a little open time on one of my days off and I am sittin pretty. With the old system the schedules were usually built with the exact same days off. You also almost never had more than 3-4 days off in a row. With the new system you can set it up right and get a lot more blocks of days off in a row if you so desire.
You can also mix up what trips you do. Instead of having to bid an entire line of stand ups you can just throw a couple in there if you want instead of having to do a whole month of them. You can throw a few locals in there instead of having to do a whole month of them. I believe our schedules are much more flexible than they were in the past. Don't get me wrong hard lines had their advantages as well. The pre assignments are definately one of the downsides but there is always some sort of give/take. All in all the schedules I can make for myself are light years ahead of what I was getting with hard lines. For this reason I would never want to go back to the old way.
It dependes on the pbs system in use. i hear Comair has a decent one. As a senior guy I like the fact that I can get a full schedule with block of 85 hrs and 19 days off. With PBS this would be less likely. As far as days off go most good companies have personal drops as well as trip trade days so you can pretty much get what you want. Management likes the PBS since it saves them money, I like the lines at my work place, if it aint broken why fix it.
I am in total agreement...Pre PBS I got more days off and more pay, plus I didn't constantly get stuck with "forced pairings" that I have no control over.
I bid 90 out of 170 and no love. I'm lucky to get 14 days off. 80-90 credit. Not user error - lots of ppl have looked it over. Days off I want? No way. I'm better off not bidding for days off at all that I need because if I do, there's no way. Mixing up trips was easy with the swapboard - especially if you could hold standups. PBS is no good to me and there are senior people - bidding within the top 20 that want stuff that junior people are getting. PBS has WAY too many bugs in it.
