LGB Communists!
AA717driver
A simpler time...
The noise nazi's in LGB nailed me earlier this month.
Over the marker in IMC after 11:00 p.m. in a GV. I can call them and they can tell me how to fly more quietly. Yeah, right.
Maybe I can violate my company SOP and wait until I'm halfway down the
G/S before I get configured. Or maybe I'll just stay two dots above the slope until I get near the ground.
Better yet, we'll just not go to F&%@ing LGB anymore! :mad: TC
P.S.--I'll bet English turned me in! :p
These idiots are infiltrating almost every airport with this B.S.
I had an interesting conversation with a certain airport manager at a small airport we frequent. He made his way over to me after we landed and explained to me that he had started a new policy of a "preferred runway" for departures. What it basically amounted to was diverting the departure aircraft away from over the high rent district over the coast and over the low rent district inland. I explained to him that the longest runway (4200') happened to be the one they didn't want us to use. I gave him the address of my boss (who resides right on said departure path) and invited him to take the issue up with him as well as reminded him that we purchase thousands of dollars worth of Jet-A that we DO NOT need just because my boss is a nice guy who wishes to support the local airport.
He seemed to adjust his attitude since and now just smiles and waves as I taxi by... I think the FBO manager muzzled the freak after I relayed what I had told him..
Lgb
TC,
If you don't go back to LGB again you're giving them exactly what they want!
Not to throw stones, but we managed in a GIV a couple of weeks ago, but it took a bit to stay below the 90db SNEL limit.
The trick is to keep going, and not let them have their way.
TransMach
I kept waiting for the call to go out to drinks, and it never came. So I got even. ;)
TC, the noise abatement office publishes a diagram that shows the locations of the noise monitors. If it's VFR, you can get in without busting (though I'm not sure about the dB of your aircraft). But you're right, you'd likely be violating SOP to do it. You'd have to stay high and off-course. But that's normal everyday flying for me :)
English--The drinks are coming--I promise! We got in at 10 p.m. and left at 10 the next morning. After 24 of 27 days in a row on the other side of the globe, we were in the get home mode. I'll be spending plenty of time in LAX this winter.
You pick the bar. Something suitably low class... ;) TC
semperfido said:
i'll be in crew rest-thank you very much :cool:
Yeah, well, I listed YOU as PIC on the flight plan while you were asleep! :D TC
Simple
Simple solution for those late nmight arrivals.
Shuttle Landings!!
TransMach said:
TC,
TransMach
Although they profess not to do it anymore, the Toyota boys at LGB have had an after 2200 hours procedure where they fly down runway 30 at altitude, then at midfield pull the thrust levers to idle and dead stick the jet around to final.
GV
GVFlyer and aeronautic--Unfortunately, the marine layer would have hosed us that night (and most others...).
I'm going to call the noise board tomorrow. I'll let everyone know the result.TC
Marine Layer?
I thought they closed El Toro MCAS.
Cali-fricken-fornia!!
What a pain in the arse.
Explain it to them in economic terms TC. Fewer flights = fewer tax dollars for their pet projects.
Legacy--They'll just raise taxes and PFC's on JetBlue customers.TC
Any word yet?
Noise Nazis...don't even get me started....
I just got busted at SNA...with my 172!!! And then there is a whole other issue at SNA. If the airplane busts...it stays with the airplane for three years...even if it is sold to another operator. In theory, you could buy an airplane that has... unknowingly to you...busted at SNA in the past, with a different operator, and YOU inherit the busts...true story, as it happened to my past company!!
Go to the FAA and change the N-number. A company I worked for had a bank of N-numbers lined up. They got busted a few times at SMO and got banned. They changed the N-number of the Lear 35 they operated and continued business as normal.
That works. Changed the N# on a GIIB more than once to keep operating in TEB. Long time ago, but I guess that procedure will still work. Anyone know?
Isn't quite that simple...see, the bust follows the serial number, as well as the tail number...not to mention that they keep the pilot info, and operator info on file as well. Then they cross reference every bust to see if there is a match in any of the catagories. I went through all of this with the airport director of SNA, because I thought it seemed a little unfair to inherit 'busts'. He simply stated "that's our policy, and there is nothing you can do about it!". Next, I wrote to NBAA, and AOPA, as well as a friend of mine at Flying, and they all came up with the same response from Mr. Murphy. 'Too bad'...
Just don't pee in the pool....
.....she has it rigged with the red dye to root out urinators.....so I have been told!!!
English knows I don't pee in pools. I may have crapped in a flight bag or two in my day, but I don't pee in pools. :D TC
The weather lately has been perfect for sitting by the pool by day, and hanging in the spa at night.
TC, you'll have to let me know the next time you are in town! And, I only put the red dye in when Jeff's in town ;)
