LGA Help please!
Beechnut
Ndugu's Foster Dad
To commute home tomorrow, I have to get from the USAir terminal to the CTB-B in an hour. Is that realistic? How do I get from one terminal to the next?
Thanks,
S.
You should be able to make it without much of a problem. When exiting the USAirways terminal, go down to the curb and go to one of the green bus stops. Look for a red, white and blue bus (they run fairly regularly) and it will take you to the CTB. It's a short ride of 5 minutes or less. Hope that helps.
Good Luck
