Let's Hear it Folks ! You Might be a FR8DOG if......
TWA said:
As a CFI, you subconsciously add 2 quarts of oil to the engine of the c172, before every flight. You then have a more "at home" feeling after your plane begins leaving its mark on the ramp.
I LOL'd
CE
You can find your company's parking spot at ORF from the oil stain just to the left of center. That happens to match up with that particular plane's drip pattern.
OH, John- and a good way to clean that windshield in flight is to keep a squeeze type water bottle in the plane. Reach out and stump some fuel, then spray at the base of the windshield. Should cut enough oil off so you can land (or pick). Still gotta wash it later though; it does tend to fog the windshield after a while.
if atc advises left or right of course approved to avoid a level 5 TS and you dont care.
don't deviate, penetrate!!! or you'll be late.
"You've ever thought 1sm and 400' OVC is practically VFR."
It isn't? I always thought is was good VFR
You only check the Wx to see how much fuel you need.
