Lear 60 vs. 45
MMO decreases? that is weird i have never seen that happen. Is that a published limitation.. reason i am asking i am going to 60 school this monday.
Yes, it's a published and taped mmo limitation. Very common in Learjets. It's likely how they met buffet margins during certification.
It's a non-issue in other jets that were well thought out, like Dassaults designs.
"I know the flex guys don't really care about them, and hammer them all the time, but folks with a gentle approach will get good life out of them."
Thats funny I care about them. I have never flown with a pilot at Flex that didnt. The only time I have sen the brakes "hammered" / or applied firmly is on a short runway or ASE and like. When stopage is assured we let of the brakes. So please dont say we dont care. Because 99% of us do. Maybe not the one you saw on a particular day.
You're right, I shouldn't have said the Flex pilots don't care. I was just looking at the data on the number of landings the Flex guys are getting, vs. the non-Flex fleet of 60's. The difference is incredible. So maybe it's technique or Flex is going into short runways all the time.
Sphrynxlla said:
ultrarunner....is it just on the newer lears?
The winglet buzz? Yeah, it's pretty much a standard deal on the 31/55/60 series.
I can speak for the 28/29 series, since I have never flow that series. It's not really an issue on the 31, but the 55 and 60 wings are pushed pretty hard as mentioned earlier in this thread, and at the heavy weights and higher altitudes, you will get a bit of "rumble" as you approach MMO. Just keep the power back the first hour and you're fine.
I would say more short runways and TR's being pinned. I am sure other operators dont fly for as long with them pinned. Thats because of the flying we do. Our maint. is top notch. We just need the time to get it done.
Pinned TR's. OK, bring me up to speed. I have just over a year in the 60, are the TR's prone to needing to be pinned on a regular basis? I haven't had a fault yet.
A normal corp operation I would say it wouldnt happen all that often. The Flex operation they get pinned occasionally. Thats also when we go to ASE 4/5 times that week with repo's to SMO. Just kidding on that, but my point is there are other reason why we may or may not go through the breaks a little quicker then most. Plus it is better to plan on an inadvertant TR stow by getting stopped then to baby the breaks on a 5-6000 ft runway. Nothing like using minimal breaking and then having a TR stow with the thrust still there. It is like a sling shot. The end of the runway seems a little closer for some reason. I think most of us like to be sure the plane is stopping then we let off the breaks. When we go to Dulles the breaks are hardly used.
Wing buzz
No problems at all in the 45...better winglet design and more wing area. The wing on the 45 is a "new" wing" even though it looks like the old longhorn wings. The 45 MMO is .81 all the way up to FL510. No wing buzz at any altitude, speed or weight.
The 31a MMO does decrease at altitude also to .78 but it has no buzz due to the light weights.
When you get to .81, or by accident a little pass .81, in the 31a you will know by the rumble, not so in the 45. Due to new cert. requirments the 45 has a larger margin before things start to happen pass the MMO
just a little more info!
Hey Lead Sled,
May be a silly question, but when you said hot wings degrade performance was that because of bleed air usage or some other reason?
not lead..but..
It uses lots of bleed air from the engines. Thus, less thrust or less power.
Throttlebender said:
Hey Lead Sled,
Throttlebender...
There's no such thing as a silly question, just silly answers. :p Remember, you can't get something for nuttin. If you take energy (bleed air) from the core of the engine to heat the wings, stab, and engine inlets it won't be there to "blow" out the back of the engine and provide thrust. As I mentioned in a previous post, heated leading edges are considered anti-icing (as opposed to de-icing) devices and you must turn on the heat whenever you are in conditions conducive to the formation of ice. This is compared to de-icing devices like the Astra's boots which are cycled to remove ice that has formed on the wing's leading edges. The other typically encounted option out there is TKS used by Hawkers, some Citations, and some piston powered aircraft. TKS systems can be used either as anti-icing or de-icing.
'Sled
Thanks. I assumed as much, but didn't really think it would rob enough bleed air to cause noticable performance loss. Now I know:)
In the Falcon 20 with the CF700-2D2 engine we really couldn't climb above FL180 with the Anti-Ice on if we were heavy... (of course even with it off it was a chore to climb much above that anyhow!)
There is a noticable difference in performance in most every jet when you turn on the anti-ice...
flyinglow said:
Question for LJ45 drivers.
Is it normal to configure for landing at 3,000 AFL, on G/S.
Maybe, Usually VFR about 5 miles out or so (outer marker area)
Schools teach GS capture flaps 20 Gear down.
The airplane doesn't pick up a lot of drag until full flaps (flaps 40)
As reported by UltraNav:
Max TOGW: 23500
TOFL: 5619
Net 2nd Seg gradient: 4.9%
V1 132
VR 140
V2 147
T.O. N1 93.7
No Wind
No Ice
Anit Skid On
Autospoilers Armed
FLAPS 20
For Flaps 8, the TOFL increases to 6065
2nd segment net climb gradient increses to 6.1%
Speeds as follows:
V1 136
VR 145
V2 153
The 45 is a great airplane. The 60 is one of those airplanes that has too much power, the gear and brakes are from the 31 making it prone to brake replacement. I have had the 45 up to 490 myself and you will get .80 out of it. I know alot of owners of the sixty love the 45 because of the increased seats and the large baggage compartment. On a side note the 60 has the worst lav system known to man. Some brilliant engineer thought that a turd would never have a diameter bigger then a quater. Genius!
Go with the 45
Cpt Splash said:
The 45 is a great airplane. The 60 is one of those airplanes that has too much power, the gear and brakes are from the 31 making it prone to brake replacement.!
Go with the 45
NO choice! im on the 60 now.
No Wind
No Ice
Anit Skid On
Autospoilers Armed
FLAPS 20
Speeds as follows:
V1 136
VR 145
V2 153
That is a TON of runway your eating up....way more than the 35. Guess the extra 5000 lbs will do it.
Cpt Splash said:
The 60 is one of those airplanes that has too much power...
Wha-choo-takin-bout Willis? Airplanes are just like cars, boats, motorcycles, snowmobiles, etc. You can never have too much power.
'Sled
