LR25
Its just a vintage VW
- Nov 25, 2001
I found using the winsheald heat about 30 min. prior to descent and then trough 18K turn the freon A/C on in conjunction with the heat and they stay clear for the most part.
The problem is, when you clear the runway and if you have a long taxi, you will be IMC by the time you hit the ramp.
Good ole roll of paper towels then.
Good luck
Good luck
