Bryan D said:This is contrary to the the principals on which every internal combustion engine operates. Leaning the fuel increases combustion chamber/cylinder head/exhaust gas temperature, a rich mixture cools the same. So how do you enrichen the mixture "so the temps don't get to cold". At any altitude I lean the mixture until I see a slight increase in RPM's or slight roughness, then I richen the mixture about 1/4 turn. If I have an EGT guage, it will be at peak everytime with this procedure. Now if I did not turn the mixture 1/4 back in, it would be lean of peak. It would be very likely that I would have detonation but would not hear it because I'm wearing a headset.
No. Peak means just that - peak temp. On either side of this peak, the temps decrease. Rich or lean, doesn't matter. The old radials were run lean of peak all the time. Arguably, slightly rich of peak is the worst place to run your engine, even though Lycoming and Continental recommend it. The biggest barrier to successfully running LOP is fuel distribution - that why GAMI-jectors are pretty much needed to run LOP.
This is especially safe when making less than 75% power. Since I operate from a field at 5000 feet, I lean ruthlessly. At low power levels you simply cannot do damage to the engine with this technique. I lean so ruthlessly on the ground that the engine can't exceed say 1200rpm without stuttering.
Read Deakin's excellent articles on Avweb and you too will become a convert just as I have.
