Lancair 320
psysicx
Does anybody have anything good or bad to say about this aircraft? Looking for a good XC bird. There seems to be current projects for sale that are a good price.
I know a dealer who sells factory built. He's been promising me a ride as I am working on selling him a second one. Sadly, like with my wife, our schedule aren't compatable. What I know of the factory built is great economy, great speed, great range (even with PAX). Up front cost is the only thing keeping people away ($350k-700k)
$0.02
$0.02
Are you sure you aren't thinking of the IV and IV-P? The 320 looks like a great airplane, though being from Washington State I'd get a Glasair II or III over the 320 :cool: . Not that I'd ever have the money though :D .
I had a Lancair 320 with the 205hp IO-360 engine. I had it for about 2 years. Fun, fast airplane. However, the older lancairs such as mine were built with too small of a tail. The airplane was VERY unstable. You can find several articles about its severe negative stability. It was also a bit difficult to land due to this reason.
Over all, if you are a half way descent stick you can handle it. Ive seen alot of Lancair 320's go from owner to owner because too many pilots have scared themselves in the airplane.
PM me if ya got any questions...
A friend of mine was killed in a Lancair 360 while doing touch and goes for practice. I've read about the instability and would personally stay away from Lancair products. Yes, I am biased in my opinion.
MM
Lancair manufactures a supior kit in all aspects. Haveing flown all make and model from the 320 the Turbine IV for many hours the 320 is good bang for the buck. fast, economical and a blast to hand fly. As for the negative stabilty...it is positivly stable, just alot weaker then the a pilot that comes from a Certified Part 23 aicraft. They ARE a cat of a different color, and do require more dilegence and vigilance to fly them. Statistaclly speaking most of the accidents in Lancair are from illinformed and not properly trained pilot who have no idea about the aircraft and how the speed and handling chacteristcs are derived. You don't get something something for nothing, its all a trade off. Which is why the aircraft is in the experimental category. The previous posts about negative stability is an absolute farce...stability is a sliding scale from negative to positve and vice versa. A Neg stabil aircraft is nearly impossible to fly, ie the F117 or the B2. All Lancair's are positvly stable, if you look at lancair's website under support there is the ability to gain insureance, and flight training through them...just look under support.
PM if you have any Questions
Closly affiliated with the factory
V1:D
I respecfully disagree about positive stability.
Although Lance, the previous owner and designer of the Lancair 320/360 will disagree, he redesigned the tail in later 320/360 models to relieve the aircraft of the inherent stability problems (see this article) http://www.eaa1000.av.org/fltrpts/lanc360/hq.htm
I too had one for a couple of years and found it the most challenging bird I flew. I put 200 hours on her and learned to love flying this fast and very unstable beast. When it came time to sell her I had a heck of a time because everyone who came to see her couldn't even handle a takeoff in her. In all justice though all of the buyers were well off privates with mooney or bonanza time and considered themselves a cut above the rest. Scared the hell out of most of them. I agree with cherrybomb, this airplane as tested is Neutral to negative stability at best. Also go to the NTSB accident site and query this aircraft....you won't be impressed...sure do miss her though
I considered a Legacy a short while back. After running a practice weight and balance, discovered that I could only fit myself and a 25 lb bag with full fuel. No passenger.
Perhaps the 320/360 has better useful load, due to a lighter airframe/engine.
I have started building a Glasair instead.
I understand what you guys are trying to say about negative stability, but (and we're talking semantics) I think what you are really trying to say is that it is close to neutral on the positive side.
If it was truly negatively stable, it would require advanced FC computers just to get airborne. The F-117 and B-2 come to mind, as does the forward swept rockwell fighter prototype, the X-29. If it was negative, the moment you deviated from straight and level, you'd probably end up in a destructive PIO. It would be impossible to control it quickly and accurately enough.
There's nothing wrong with saying "it's a handful", but don't say it's got negative stability because that's simply not accurate.
Unstable in what way? In phugoid, the long period (~30 second peak to peak) pitch occilation? An airplane can be unstable in phugoid and still be flyable, just a lot of work. Some of the early jet fighters were instable in phugoid. All the early swept wing jet transports were unstable in dutch roll before they put yaw dampers on them.
Scott
As your article states, and as you refer to the potential buyer (Mooney and Bonanza types) of the aircraft it discusses FAR part 23. This is an expermental aircraft, not only because it is built buy someone with potenetially little formal training, but because it will never pass alot of the requirements for a Part 23 Certificate. Again ALL Lancairs are POSITIVLY STABLE. Stability comes in a wide range, from very stabile and docile 172 that are trainers with little manuverability to very manuverable and less stable Extra 300. Its all a trade off. Stability, Manueverablity and Controlablity are all different from each other and only loosely related to each in each others function.
Lancair's get it's speed from a very clean and efficient airframe and slightly less then PART 23 requirments for stability. If you are trying to compare aircraft, then don't compare "apples to oranges", ie. mooney, bonanza's and the like. I have personally flown the ES with Full fuel and four Adults and Bags at Full Gross wieght, never came close to the aft CG and still climbed at 800 ft a min/160KTS to 10,500 msl @ ISA +14, AN then accelerated into a 215 Knots True Airspeed Cruise, While burning 13.0 GPH. Neither a Mooney/Bonzanza nor a 206 could acheive this without a slight reduction in stability and other parameters required by FAR23. Does that make the aircraft unsafe, no, Only the pilot operating it without proper training.
Less stabilty is just more workload. I have flown all the models from the 320 through the Turbine IV at ALL spectrums of CG, Full aft and Full Forward, and have NEVER found anything that wasn't going to be expected for such conditions.
Type specific training is required to "unlearn" some of the techniques that an instructor taught during inital flight training to be safe. Simply put, apllying what you already know form a Cesnna, Piper Beech Mooney is unsafe. Period. You need to be responsible and LEARN about the aircraft that you intend to fly. A Single Engine Land rating is simply not enough to undertake a high performance airplane like this. Yes, accidents do occur, but its the pilots fault, not the airplanes fault.
V1
