Is it worth equiping with RVSM? How do the legs compare to a 200?
You'll never use the RVSM with a 300 if you don't go out west.
I flew one a few years ago. The best Alt's for speed's/ff's happened to be in now RVSM terriority.
But even then you are still only 315kts. That is a good 100kts slower than the slowest of jets. You'll be out of RVSM airspace so fast you'll look like a brick with no wings or engines.
The B200 is a bad choice too. It is really a 200 with better (read higher dif.) pressurization. So, again another animal that doesn't need RVSM.
Its a waste of money. Or, just a big ego.
But, the 300/350 is one heck of a good machine. It burns much more fuel down low compared to a 200.
The 300 is a great machine. It is just to slow for RVSM.
Mx on the 300/350 is a lot more than a regular 200. You have time limited (not just hour limited/cycle limited) components and extra mx issues that a 200 doesn't even worry about.
If you don't go over 600 nautical miles per leg you'll be better off in a 200. Unless you have lots of money and a need for the payload of a 300 or 350. Since they don't make 300's anymore you'll be at the used end of the 300's and the avionics vary greatly from years to years.
You can get a much better and newer 200 for the value (read dollars) of a 300 with all other things being equal.
Training is another gotcha. You'll have to be typed for the 300/350. And, must go to rct every year.
The 200 is the most popular t'prop for a reason. It is a 12,500 machine for a reason.
Good Luck.
