Jumpseat Question for USAir Express guys
PTinbound
Kool Aid CEO
Hey guys,
I had a four day that I gave away the last two days of, so I'm trying to get home on flight 2459 PHL-DTW on Friday night. I have no idea even what carrier it is because the USAir timetable doesn't say. I've never been anywhere in PHL except the Southwest gates. If I get in at 9:40 and my jumpseat leaves at 10:15, is it even possible to make that connection? If so, how far and where do I go? Or should I just go to the hotel and come home in the morning?
Thanks!
Hey, PT -
No worries. You park in "E", right? Your flight US2459 will be parked in the "F" terminal. Unfortunately, your best bet is to leave the secured area and walk over. The only other way involves going to C16 and riding a shuttle, I believe. Security will let you cut in line, though, so you should make it.
I'm pretty sure your flight is a PSA CRJ200. Heck, I'm on reserve Friday......maybe I'll see you there.
Good luck.
I would say that it's pretty tight. You guys are at the end of E, so you have to walk the length of it (not that long), exit security, make a 5 minute walk to F, go thru security then walk to your gate.
As long as you're a bit early I would say no problem, if you;re right on time though, and still have to check in for the jumpseat, I would bail off the plane right when the door opens to ensure you have time.
Good luck!!
