Our Pro standards is a waste of time and a paper tiger. 100% worthless, with a bunch a little girls in the positions. If I was the said pilot, I would go down to DAL(solo) and talk to SWA mgt. .Tell your side,dont lye and man up. SWAPA Pro, Standards would hurt this guy more than help.
That's a shame. Pro Standards has the potential to be a valuable tool for us. The AirTran Pro standards seems to have been a good 'stop gap' that our CP has allowed as an alternative to the hammer. There are obvious exceptions where politics, Union stuff etc. got in the way.
It is a shame about our pro standards. They are mostly egomaniacs that want to become a check airman,except the company knows them for who they are. Actually some of our PS pilots are high avoidance for the FOs We have had several pilots at SWA threaten pro standards that if they keep up there unprofessional behavior they will take it to the CP. I personally would rather deal with our CPs. They are a good group and I have seen them many times bend over backwards for our pilots. If I was incharge of SWAPA, pro standards, it would be ALL First Officers. NO captains.
Like I said, if this AT guy in question is a good guy, that made a mistake. I think he should go to DAL and man up.
I am very curious the ways your ProStan is harmful? It's supposed to be the protection for handling a problem without it going to management.
What do they do?
Thats a pretty sad reflection on your "Union".
Pro standards is telling the pilot that picked up the trip to to just suck it up and give it back,
I hate to say I agree with you on this. ALL P/S does at SWA is protect the dic heads like yourself.
That's just wrong. If the original pilot dumped the trip then HE has to suck it up. Once the trip is gone, its gone.
That's quite an assumption. If, however, what you say is true, your ProStan committee is 180 out from what they should be doing. ProStan is supposed to be the cushion between the pilots and the Company. If you get more satisfaction from going directly to the BCP, then your ProStan committee needs to be disbanded or gutted.
Ok you need to stop posting stuff I agree with
PS have a good thanksgiving
Good ideas chase.
What "teeth" do other airline'sPS's have?
Good ideas chase.
Well, NO ProStan committee has real "teeth", however, a properly run program can rein in bad actors before Company disciplinary action has to get involved.
If you have a respected committee like ours, the Company will even refer a problem to them in order to avoid having to officially discipline a pilot. If the behavior continues beyond that, then the discipline system is invoked.
Now, in your case (apparently) your committee is so backwards, the average rank and file pilot prefers to refer problems directly to the BCP simply because they're not getting any satisfaction from ProStans.
Fubi,
4. Some wear their reputation as being a pain as a "badge of honor"...why? Because they can hold pro stds off at arms length while smiling politely in the CP's office saying, "I didn't violate the FOM, I flew the airplane within limits and my social skills suck...you can't fire me fro that?"....and so they walk.
While "hostile work environment" gives companies greater leeway than in the past, unions must still defend the bad actors. Who represents the FO (or CA) when he complains? Pro stands but again who have the leverage? The bad actor since he hasn't violated any directives but simply violated commonly acceptable modes of behavior.
Slaquer5,
My apologies if my comments offend you or come off as knowing more than you...I'm not a pro stds guy nor have I been one.
I have spoken a lot to CPs, union reps, pro stds persons at SWA and other airlines about the topic. I have also seen the scenario I described up close and in person with a CA I flew when years ago.
I have heard similar stories told me as an FO and after I became a CA.
If you believe my statements are without evidence, no worries...they are based upon interviews with management, union personnnel and many pilots who have confirmed the same type of experience I encountered.
The frustration felt by some within pro stds and their eventual departure is partially fueled by the bad actors walking the line and feeling ineffective in making changes.
We obviously have different experiences and thus different opinions.
Pls provide if you wish your remedy for correcting bad actors? Thanks in advance for your reply.
Fubi,
I don't know what type of program your airline has but the following would surprise me if it isn't true:
1. Isolated incidents do get fixed by our Pro Stands and when necessary our CPs and I assume yours also.
2. The "true bad actors", less than 1%, know precisely where the line is and what they can get away with and when the union "must" represent them.
3. A "bad actor" is under no pressure/incentive to respond, comply with or engage with pro stds if they don't wish to. Again, this isn't their first rodeo and play the system like tournament level players.
Get the company out of the mix and let the associations work the issue internally with tools that can affect change. After the first couple of bad actors are marched through the gauntlet, other trouble children will not want to be dragged through the consequences or process.
Make it painful enough and people change behavior....we have programs for those with drug and alcohol problems and they are successful ...why? Because folks are motivated to not run afoul and suffer the pain/consequences....the same can be done for bad actors toward our own if we as pilots are willing to tackle the issue as group instead of leaving it to management.
Well, I can tell you this...our CP has been known to refer cases to ProStan because he wanted to give someone a break. If the Union could take care of the problem, then he didn't have to bring the weight of Company discipline down on them.
