JetBlue Online APP
P-3Hawk
Member
Anybody out there that give some advise on the online App for JetBlue would be great. Everytime I hit submit I get all these discrepences, and when I correct they don't goaway.
any help would be great Thanks P3Hawk
You are not the only one...I had a hell of a time filling in this app. including having to add more RAM to my computer (but that's another story)
Without knowing the individual discrepancies, I can't help you much, but I do know that if the discrepancies do not go away you are not fixing them, even if you think you are! One area I had problems with was the date fields. They must all be filled in...if you are presently employed then the 'end date' must have something in it. I just put the present date in there. At first I think I tried putting 12/31/02 in the 'end date' field but that also upset it.
All I can say is go through each discrepancy one by one and work though it. You will probably find that you are making the same mistake multiple times, and one simple fix will cure all the errors.
Good luck!
Check availabilty date
P-3Hawk,
I can feel your pain. I logged on to update my app last month, after submitting the original data last March. All my times for each A/C flown showed ZERO. So I updated, printed it out (again), and e-mailed them to let them know. Then I took a peek at my "JetBlue info file" and noticed the app copy I made in March had the times, so their computer obviously droppped my times to zero for some crazy reason. I still have not received a response from them on this. Probably due to the fact that it's a bigger problem than they want to admit. Three friends of mine had the exact same problem.
Anyhow, I logged in last week and it looked O.K.; so that problem seems fixed, but it's 6 months lost for me and my buddies. It seems I saw a post a few weeks ago about updating your availabilty date to also make the data input stick. If you do a search you should be able to find it. If not, send me a PM and I'll hook you up with a guy here on this forum who might be able to offer you some advice on the problem. He's with JB now.
Good luck,
Coop
JetBlue app
I finally got through the obstacles of getting my app into J-Blue.
Thanks again for the advice. Iguess the secret is to go through the discrepances correct them, submit and then log out then back on again to clear them??? anyway it worked for me. thanks again
Happy Contrails P3hawk
