Jungle Prop
Living the dream - NOT
- Nov 28, 2001
Flying the Line said:They are landing at LAX so they can cause delays for all the other airlines and get lots of free publicity at the same time. The nose should freely caster on landing.
Good luck guys.
N905TW said:Wow, reminds me of the video we saw in new hire training about the exact same incident at AWA a few years back....... thought they had fixed this problem....
NTSB Identification: NYC99IA062 .
The docket is stored in the Docket Management System (DMS). Please contact Public Inquiries
Scheduled 14 CFR Part 121: Air Carrier operation of AMERICA WEST AIRLINES
Incident occurred Tuesday, February 16, 1999 in COLUMBUS, OH
Probable Cause Approval Date: 5/9/2001
Aircraft: Airbus Industrie A-320-231, registration: N628AW
Injuries: 31 Uninjured.
When the landing gear was lowered, the flight crew received landing gear control and interface unit (LGCIU) faults. A visual fly-by revealed the nose wheels were rotated 90 degrees from the desired direction for landing. A normal touchdown was made, after which, the captain commanded an emergency evacuation using the overwing exits. Examination of the airplane revealed the external 'O' rings in the steering control valve had extruded and by-passed pressurized hydraulic fluid to rotate the nose wheels. This event had occurred before, and the manufacturer had issued a service bulletin. The operator had not complied with the service bulletin, nor were they required to comply with it. The National Transportation Safety Board determines the probable cause(s) of this incident as follows:
a failure of the external o-rings in the nose landing gear steering module.
Full narrative availableIndex for Feb1999 | Index of months
http://www.ntsb.gov/ntsb/brief2.asp?ev_id=20001205X00227&ntsbno=NYC99IA062&akey=1
AKAAB said:Nose cannot freely caster - trust me on this. The rubber will burst and the rims will grind down causing some sparks - nothing more. There is no chance the wheel will suddenly caster to center from 90 degrees offset.
