• NC Software is having a Black Friday sale event November 26th thru 29th. Use coupon code BF21 at checkout to take 15% off your purchase for eligible products. Visit https://nc-software.com to shop now.
is this real an F-14 flyby
FL000
Total Time
1500
Yes. If you look very closely, you can see the navigator writing a check for 19 million dollars, his half of the hull loss.
Chunk
SkyFuzz
Total Time
others in the photo
The 14 is being flown by Snodgrass, as the board discussion says. The two others in the white floatcoats are Jay Johnson (former CNO) and Boomer Stufflebeam (my former CAG [CAG-1], and now admiral/pentagon spokesman).
Chunk
bssthound
Enormous Member
Total Time
xx00
FL 000,
You never, ever, ever refer to a backseater as a "navigator." Doing that regularly runs up the bar tab dramatically. Even though he went through navigator training he is a WSO or a RIO, depending on branch of service. A prior WSO like myself is a "Wasso."
FL000
Total Time
1500
I had a feeling that I'd get stabbed for that one. I even tried to research it to make sure it was the proper term. Anyhoo, sorry for the misnomer. Since my ignorance is already on the table, I'll ask another one: is there a stick back there, or are you a passenger?
XNav
Active member
Total Time
6K
The hound is right. Not only do they hate being called that, but very few of them can actually navigate! You can call RIO's "NFO's", however. That stands for Naval Flight Officer, (or "No Future Outside" the Navy). There is no stick in the back of a Tomcat. I think RIO's are nuts, but I must confess to having a grudging respect for anyone with the balls to sit in the back while someone else flies them aboard....especially at night.
bssthound
Enormous Member
Total Time
xx00
a BIG stick!!
The Air Force two-seaters traditionally have had sticks at both crew positions. I think the only exception is the EF-111 "Spark Vark." I know the "straight" F-111s did have them.
XNav pretty much nailed my navigational skills. When the GPS goes "funbags up" I'm pretty much a couple seconds after it!!
Toro
Total Time
2000+
The Strike Eagle has a stick and throttles in the back seat. With the exception of a couple switches, the main things that the back seater can't do are shut down the engines or put the gear down normally.
Chunk
SkyFuzz
Total Time
One Anchor good, Two Anchors bad! ;)
It's not just NFO's back there, in the S-3 there were 2 guys in back, including a Naval Aircrewman. Notice the past tense, they eliminated the enlisted guy, said we cost too much $$! Never could figure out how an E-5 cost more than an 0-3. Shoulda put 2 Senso's in back, saved even more money, and kept all the capabilities of the aircraft. (Can't do ASW without the SENSO)
Chunk <---former SENSO
(Not that I am biased or anything)
