IR checkride questions
SennaP1
Livin' the European Dream
I have two of my students going on IR checkrides in the next week, I was wondering if anybody here had any good questions (stumpers, real life ones). I've exhausted everything my fellow CFIs and the Examiners gouge could come up with. I know there is plenty of experience on the board.
Thanks in advance guys/gals
approach minimums
If visibility is reported as 1/4 mile and the approach requires 1/2 mile, are you allowed to shoot the approach? (yes you can shoot the approach)
Inbound on that ILS and the approach lighting system is in full view. Can you land? (yes you can, the ALS is at least 1/2 mile long so you have adequate FLIGHT visibility)
PanAm,
Not entirely.
If only the approach lights are in view, regardless of what the visibility might be deemed to be, you may not land unless the red terminating bars or the red side row bars are distinctly visible, if using only the ALS for the approach. In this case, unless the red siderow bars or terminating bars are visible, you may descend to no more than 100' above TDZE.
If in addition to the ALS, one of the remaining criteria in 91.175(c)(3) are met, then the aproach may be concluded to a landing.
Under Part 91, regardless of the minimums, if the required visual references are in sight, one may land.
What's the difference between a turn coordinator and turn and bank indicator?
When may one fly IFR without a clearance, and without talking to anyone?
Flying an ILS backcourse with a HSI, what is set in the OBS for the HSI?
What is the true value of a contact approach? (Why a contact approach instead of a visual approach, and why would a pilot request one?)
If lost com occurs during a vector, what to do?
Ginger, or Marianne?
IFR questions
What do you do if if you're given a hold clearance and an EFC time and you don't receive that further clearance?
Why is it SO important to note your time off when you're on a clearance?
Why is is so important to specify the IAF when you file your IFR flight plan? (Because if you lose comm and you arrive early you to fly to and hold at the IAF until your at the end of your flight-planned time enroute and shoot the approach.)
Do you have to call Flight Service to close your IFR flight plan if you land at a controlled field?
Any and all lost comm questions are always excellent.
VOR check and checkpoint questions are always good.
Inop components are good.
MEA, MOCA, MVA, MSA questions are good.
Icing questions are good.
DO make sure your students understand to keep the volume up on the ADF during their NDB approaches. DO make sure your students tune and identify every station. DO make sure your students know to run a complete check of the marker beacon panel and that the OM, MM and IM lights come on.
DO make sure your students know which way to set the OBS on an HSI for a back course, as Avbug said.
PS-A few more.
The 1-2-3 rule.
Currency. They should know about instrument proficiency checks (fka instrument comp checks). In the old days, you could go up with a CFI-I and shoot a couple of approaches and maybe a hold and that was it. Now, the PTS sets forth what is required in an instrument proficiency check.
Gyro instruments. Rigidity in space. RPM needed to keep a gyro rigid. Pendulous vanes. Differences in gyro instruments, especially the differences between a turn-and-bank needle and a TC. Why is the gyro angled on a TC? Why the TC is electrically-powered on most light aircraft while the others are vacuum-powered.
The basic six-pack of instruments. Signs that your static source is clogged and what to do about it.
It really depends on the examiner. Get the gouge on him/her if possible. All examiners are very different. Here are some of the questions I got.
When do you have to go to your alternate? (ONLY when you are lost coms: This is not to be confused with a different approach at another airport close by.)
I also was asked the question above about the IFR flight with no clearance (class G airspace).
You are 15 miles from the station and have one dot deflection. How far from the station are you? (1/2 mile)
Hold question..right hand pattern: You are on a 360 degree bearing to the station with a 10 degree left crosswind correction. When you cross the station and turn outbound AND you're abeam the station, what will be the relative bearing on the ADF?
You meant 1/2 mile from course, right?
your last question:
If you have doubled your outbound crosswind correction, your relative bearing when abeam would be 70 degrees. Am I correct?
16. Explain the three types of holding entries.
17. What are the maximum airspeeds in a holding pattern?, and are they IAS or TAS?
18. Why don't we use the same WCA (Wind Correction Angle) outbound as inbound?
19. What does PNIR stand for?
20. What advantages do we have for not listing an alternate?
21. What are the standard alternate minimums?
22. Where do we find non-standard alternate minimums and/or restrictions to the minimums?
23. Under what circumstances may we file an IFR flight plan to an airport without a published instrument approach?
24. What kind of fluid is in a magnetic compass and why.
25. Can we get a special VFR clearance between sunset and sunrise?
26. How often do VOR receiver accuracy checks have to be made for IFR currency?
27. What are the 6 methods for checking the accuracy of a VOR before IFR flight?
28. In using a back course localizer for a departure, do you correct towards or away from the needle?
29. What are the reporting points that are mandatory by FAR?
30. What is the frequency, signal rate and signals of an:
Outer Marker?
Middle Marker?
31. What standard separation is guaranteed by ATC under IFR?
32. What is the frequency band of a glide slope (LF, MF, HF, VHF, UHF, etc.)?
33. How are LOM and LMM identified (ie by letters, morse code, voice, or other?)
34. What is:
RVR?,
RVV?,
Prevailing visibility?
35. When do you cancel your IFR flight plan?
36. What is the meaning of:
"VFR on top" ?
"VFR over the top" ?
"IFR over the top" ?
37. Does an aircraft on an IFR flight plan,making an approach, have priority over VFR traffic?
38. Explain what to do in an event of a communication failure.
What route would you follow?
Altitude?
When would you start your descent and shoot the approach?
39. What does "cleared for the approach" mean?
40. What is the difference between a back course and front course approach
41. A holding fix is an NDB, when do you begin timing the outbound leg of the hold.
42. What is
HIRL:
REIL:
RAIL:
ALS:
SALS:
PCL:
43. What frequencies are ILS localizers on?
44. What is the color and coding of the:
Outer marker?
Middle marker?
Inner marker?
Back course marker?
45. How much instrument time must be logged to remain legal for IFR Flight?
46. What does the term "radar vectoring" in the communications group mean?
47. A glide slope facility provides a path which flares from____ to ____ feet above the runway.
48. When don't you have to make a report at a solid triangle on an L-chart?
49. What band of frequencies are compass locators within?
50. What is the difference between a "feeder facilities ring" and an "enroute facilities ring"?
51. What are the three AGL altitudes on an ILS approach chart?
1)____
2)____
3)____
52. For what reasons would an instrument rated pilot, on an IFR cross-country, request a "VFR on top" clearance?
53. How accurate are the SDF and LDA approaches.
What are their similarities.?
54. Where do we find the inoperative components table for an approach?
55. Do two or more in-operative components have a cumulative (negative) effect on approach minimums or do they negate the use of the approach?
56. When is a standard hold more than one minute in length?
57. If you are going faster than 175 KIAS, when should you make a speed reduction to enter a hold?
58. What is a "visual approach"?
59. While shooting a PAR approach, if you lose communication for _____seconds during the final segment, you should:
60. What is a "transmissometer"?
(From a list of 180 impossible or thought provoking IFR questions assembled by devious minds at our airport!)
Can I get that whole list of stumpers? I'd love to add it to my personal website, if that is acceptable.
At my school we use a 149 question quiz for our IR students. It is at http://www.myfbo.com/ghft/ifr.html
Any tips for a student that is petrified about her upcoming instrument checkride? She's been in a steady backslide since the word "checkride" was mentioned to her. Her skills were excellent at that time, but now she just gets too nervous, then gets mad at herself, and it's a graveyard spiral afterwards. The student has been working on the rating for two years and has conquered many fears. Her biggest fear now is of failure.
Fly SAFE!
Jedi Nein
Marianne.
Not as fancy an airframe, but I imagine better performance characteristics in a wider variety of configurations.
This is not really a test question and is difficult to apply to a 172 as you generally do not have an accurate fuel gauge( actual pounds of fuel left) however it seems that many new pilots dont seem to have a concept about what is commonly referred to as bingo fuel. a predetermined point when we are going to leave the hold pattern and head for the alternate- or if winds or routing were different than planned you may already be at that point and holding isnt really a valid option
2)differnce between grid mora and route mora.
3)if you use jepps what criteria do they use to determine if in Mountainous terrain...ie.. apply two thousand feet to mea
4)on jepp charts they often show terrain- brown shades for high terrain when greater than 4000 feet above airport or when 2000 within __ miles of airport
5) the vasi provides and accurate g.s. indication and terrain clearance when within 4nm and 10degrees either side of an extended centerline
6)how far is a H vor good for.. depending on thae altitude(18-45) 130 miles. I bet you can find a chart with an airway that has more than 260 miles between the vors. Can we fly that airway? yes because those are only standard service volumes for direct and random routes and do not apply to flight tested routes
7)if they ever get to a larger airport do they have any idea what ry guard lights are- or clearance bar lights
8)Only a personal observation but on my days off I had started doing some cfi work at Farmingdale- this was a couple of years ago and one dayabout 30 degrees outside and 1500 overcast--definite icing conditions another instructor and student were getting ready to go get some ACTUAL. The instructors reply to me was that the mighty 172 can pack alot of ice.. and besides there were not any pireps about icing in this area.this could mean,,,
a) could be lazy pilots dont like making pireps..
b) in a big plane that trace of ice seemed insignificant and they quickly left area before they had time
c)pilots flying different equipment will have totally different experiences with ice- mainly do to different speeds-- often times large jets penetrate icing conditions at high speeds and you never see accumulation(besides the point but they are also equiped to fly in this) Whereas a slower aircraft will be a litteral magnet
9)What is a visual descent point
Explain the three types of holding entries. One wrist turned outbound, cuffs in the strong hand. Facedown, hands on back of head. Two man, both wrists restrained and twisted outward.
What advantages do we have for not listing an alternate? No incriminating evidence.
What are the standard alternate minimums? A very liberal spouse, and a large checking account.
Where do we find non-standard alternate minimums and/or restrictions to the minimums? Usually in church.
What kind of fluid is in a magnetic compass and why. Wiskey. That way it can be consumed in the event of a horriffic injury, and can be used to sanitize wounds. The origional intent was to use tequila, but the worm causes binding on the compass needle bearing.
What are the 6 methods for checking the accuracy of a VOR before IFR flight? Striking the face of the instrument. Removing the instrument from the panel and rattling it. Applying extra voltage to see if it holds up. Tuning to a local station and then holding a magnet near the omni head to see if it screws things up. Tuning to a local VOT station while shaking the airplane violently to simulate turbulence. Actually flying the approach under IFR, and if upon breaking out and finding that the approach looks about right, quickly pencilwhipping it and backdating the entry a day or two.
In using a back course localizer for a departure, do you correct towards or away from the needle? Depends if you have a HSI and dialed in the front course, like a good boy.
What is the frequency band of a glide slope (LF, MF, HF, VHF, UHF, etc.)? Punk, I believe, and twice nightly at the Paladium and three times on Saturdays.
When do you cancel your IFR flight plan? Just prior to going in the clouds. That's scary stuff, and it's better to cancel, duck underneath, and fly where you can see what you're hitting.
Does an aircraft on an IFR flight plan,making an approach, have priority over VFR traffic? Depends how big it is, and how gutsy the VFR traffic wants to be.
Explain what to do in an event of a communication failure. I assume prayer and screaming aren't part of the equation. Descend below 50 AGL and read road signs. This also has the added advantage of ensuring accuracy when dropping signed messages to gas stations and road houses, to pass on to ATC for you.
What route would you follow? The one that leads in a direct line to Disneyland.
Altitude? Thank you. You too.
When would you start your descent and shoot the approach? Within three minutes of my ETA to Disneyland, or four minutes of needing to go tinkle.
What does "cleared for the approach" mean? It means end of the third date, and all the right signals are there.
What is the difference between a back course and front course approach? Generally how well you know someone, and certainly personal preference.
A holding fix is an NDB, when do you begin timing the outbound leg of the hold. Abeam the ankle.
What is
HIRL: Also pronounced "Hurl," a term meaning "to vomit."
REIL: Defines the differnce between virtual flight and actual flight. Also sometimes stated as "It's been reil."
RAIL: Used to strike errant students about the head and shoulders during flight instruction
ALS: Advanced life support. Used to keep overweight captains alive and kicking until they can get on the ground and die in their own bed.
SALS: A hot topping best reserved for tortilla chips
PCL: Politically Correct Landing: one you can walk away from, and still smile
What does the term "radar vectoring" in the communications group mean? The communications group is pretty informal, and most of them understand this really means "let's do lunch."
A glide slope facility provides a path which flares from____ to ____ feet above the runway. A glide slope doesn't flare at all. Category 1 approaches aren't flightchecked below 200', and this negates the concept of flaring.
When don't you have to make a report at a solid triangle on an L-chart? Because my kids probably drew it there, and darned if they're telling me what to do.
What band of frequencies are compass locators within? Little River Band, from 1995 to 1998. Presently working on a new album, independantly.
What is the difference between a "feeder facilities ring" and an "enroute facilities ring"? One does primarily fast food, catering to truckers and those on the road, while the other is more of a sit-down meal.
Where do we find the inoperative components table for an approach? Usually in the repair shed, but these components are best left alone for competent repairmen to handle.
When is a standard hold more than one minute in length? With prior approval, only after the third date, and remember; "No" always means no!
What is a "visual approach"? One where she sees you coming across the room, but can't escape. Used only on blind dates where one thinks one has a chance.
What is a "transmissometer"? Used to power the drivetrain of most modern french automobiles; converts engine power to wheel power. Also a device which lets one know just how much one is missed.
How did I do?
I have an excellent one
Depending on where you are in the country, show your your students enroute charts from someplace opposite.
For example, I took my ride in the great state of florida, and until my ride had never seen a mountain on an enroute chart. I guarantee your student will appreciate that "first" before the examiner lays out a chart of the greaer Denver area and asks him "what is that?" :)
ali
Examiner ?
Heres one I got:
You have 30 min fuel remaining. Already went missed twice and youre at your alternate and went missed again. No VFR weather within range or PAR available (yeah, you painted yourself right into a corner). you have an ILS you just went missed on infront of you. What do you do?
Answer he was looking for:
1. Declare an emergency
2. Follow the ILS down to the runway as best you can.
3. For Gods sake think about this question when you plan your flights and dont paint yourself into a corner like that!
Final point--you are the PIC; its your job to get the a/c on the ground as safely as possible. Also--always remeber an airport with emergency equipment beats hell out of anywhere off-airport.
PA
Oh--Avbug-- Marianne, definitely Marianne; shed be certified aerobatic, not ultralight....
Timebuilder,
You got me not thinking straight!!! You are correct about the 1 dot off problem. I was thinking 30 miles out........not 15.
As for the hold question, remember, we triple the inbound correction on the outbound. Try that one 1 more time and I believe you'll have it.
You other guys also have some great questions. SennaP1, you should have plenty to work with here.
Thanks.
Actually, an experienced pilot told me last year that his encounters with holding showed him that doubling the wind correction angle worked better than the tripling of it that you and I were taught.
He explained that it's one of those things that are expected on a checkride, but which are not required in regular operations. Since we're talking about checkride questions here, I should have given the more standardized response.
Yeah, it can be frustrating to find that the standard that we've always been taught is not always the best way to do things. I just came through a CFI academy at American Flyers and was shocked to learn that a lot of my prior information that I was taught was either wrong or incomplete. Students should learn early that they should question everything they hear and half of what they see.
That's news to me. I don't double, triple, or do anything to correction outbound, ever. I've never heard it, never done, it , never taught it, and never had a problem. Sounds like some folks practice it, but it's never come up on a practical, interview, sim check, proficiency check, or any other check.
Then again, the last time I got a hold in real life was some time around 1988.
Thanks for all the input I'm copying and pasting as we speak and going to give them a try on my students.
Thanks again..
One more thing...
I use Jepps, and I had no idea what are those dashed rings around airports on NOS Charts that say" Feeder and Enroute Facilities"
Senna,
The facilities rings are not to scale, and are just used to give a general representation as to where feeder facilities and enroute facilities are in relation to the proceedure. It's just a reference, and facilities associated with the proceedure that would be too far out to be charted, are placed on these rings. Thus, a VOR that serves to feed a NoPt route to the IAF might be 50 miles away. Too far too chart. But it's northeast, and that's where it will appear on the feder facilities ring. For a better picture, you need to also refer to the low altitude enrotue chart.
A side note, don't mix jepp low altitude enroute and government plates, if you can help it. It can be done, but it can also lead to some confusion.
required reports
I think all examiners have their pet topics. My examiner's favorite question was regarding required reports and when the pilot must report to ATC. He sat back like a quiet kitty while i rattled off everything I had learned in ground school and from independent study, then viciously pounced as soon as i finished spewing information. It became clear to me that I was not his first victim as he opened his FAR/AIM to highlighted passages in both the FAR and AIM sections. I was in such a state of shock I'm sure I didn't comprehend everything in his tirade. The gist of it was...there is a difference between "should," "shall," and "must." Jeppesen, ASA, etc., ambiguously teach required reports as a must, using both "must" and "should." In reality, the 10 or so "required reports" are actually not required and you may make these reports only if you feel like it. The required required reports are only three and are listed in 91.183. AIM 5-3-3 lists required reports and as we all know, the AIM is not regulatory.
In the end, I passed the exam, but I was a mess by the end. I didn't really understand why he made such a fuss about something like that. :)
Required v. Recommended
The examiner is correct, but most people I've known have considered the AIM to be quasi-regulatory. You know, if Uncle Sam and the FAA take the time to produce it, it must have things they want you to do, right? That was always my approach and my CFI colleagues took the same approach. To my recollection, I never had Instrument students bullied on that issue.
You're FSI meat, aren't you? I'd appreciate a private on which examiner, to see if it is one I knew and didn't like.
outbound vs. inbound correction
You need to double or triple your outbound wind correction to compensate for the change in your turn radius as a function of groundspeed. When doing this, you will not be flying a perfect racetrack pattern, which is OK.
Holding the same WCA outbound as you did inbound would cause you to parallel your inbound course. However, when you start your standard rate turn back inbound, the wind that was fomerly at your side is now at your back, increasing your GS, and widening your turn (compared to the turn in which you were flying upwind.) In this scenario, you will either blow through the inbound course onto the unprotected side of the hold, or you will have to increase your bank angle well beyond standard rate to sufficiently tighten the turn and roll out on course.
It is much easier to explain when you draw it out.
By the way, I actually really liked the question above:
If your're 15 miles from the station with 1 dot deflection, how far from the station are you? That may actually trip some people up.
-FB
Good explanation, Brian.
Yes, you'd still be 15 miles from the station. I guess "trick" questions are fair game.
It makes sense, but much like typical ADF proceedures (which resemble some bizarre algebraec formula), it's too much headwork when flying. I've never done that, and never had a problem.
If I'm holding a bit of correction one way or the other, I hold it and perhaps a bit more. How much? A bit. If it's a lot of correction, I'll hold a lot, plus a bit.
What really counts is turning in bound and intercepting the course. As wind is a variable anyway, and during the hold we're not flying a precise ground track, it's largely all guestimation anyway. If the needle comes in faster, increase the rate of turn to intercept. If I'm farther out on the outbound leg and the needle doesn't come in as fast, slow down the rate of turn. Fudge for success.
Too much math.
Holding
I agree with Brian. Try it sometime in the sim. Crank up some good crosswinds and try doubling or tripling your outbound correction. Then, take a look at the paper trace to see how it works.
Anyone for time and distance to station? Is that still taught and/or tested? I never had an instrument student tested on time to station.
I'm actually with you on the practical side of it avbug...
But it helps your guesstimation if you know that you'll have to hold more correction outbound then inbound. incidentally, it doesn't matter what direction the wind is coming from, you still correct more when you're outbound. This is an easy question that can trip you up if you don't fully understand the concept.
Agreed, Brian.
My most challenging holding happened during my instrument training on a windy night in a 172. I flew the hold for almost 1/2 an hour, and had a 12 degree inbound correction and a 36 degree outbound correction when I was through.
I never had any trouble with holding after that.
