aviatornick
- Aug 1, 2004
Do you still get left turning tendencies with jet aircraft? That's really cool...I thought it was just prop aircraft...cool....aviatornick said:do you really need a rudder with larger aircraft? i doubt a captain or first officer on a 737 thinks about adding right rudder during their take off roll.
i could be wrong
Nominitour said:Do you still get left turning tendencies with jet aircraft?
You do in high-bypass turbo-fans, though it is much more subtle. The higher bypass the engine, the higher the percentage of thrust that is being produced by the fan. Fan blades have ascending/descending blade issues just like props do. On takeoff roll, most of the time you are correcting for the centerline with rudder (and nosewheel steering via the rudder pedals) because of the engines spooling up at different rates. However, it seems like nine times out of ten, your initial correction is with the right foot.minitour said:Do you still get left turning tendencies with jet aircraft? That's really cool...I thought it was just prop aircraft...cool....
-mini
