Brasilia Pup
Space Shuttle Door Gunner
- Apr 15, 2004
Not necessarily true. You may turn early because the protected airspace left and right of the inbound course is large enough to encompass the airspace you would be in if you turned inbound early. It would be the same amount of lateral protection when performing the straight in approach.This is like a Procedural Track. I have flown with a number of professional (paid) pilot who wanted to turn "early" and not follow the track. I told them that their idea is wrong. It is NOT protected airspace. It is a TRACK and you the approach is designed for you to follow the track as closely as possible.
It is also like a 1 minute holding pattern. You turn at 1 minute, not at 30 seconds.
In the above description 4 miles is NOT the protected airspace. When you turn AT four miles, as depicted, you plane will go OUTSIDE of 4 miles during the turn, as the people who designed the approach planned for your to do. The protected airspace will extend safely beyond the turning radius of your aircraft, which may be very large, for an airplane requiring a fast speed on the approach.
