New guy,
Been out here at LAX for just about a year, and as far as I know, there isn't a way for you to get notified, unless you log into vips. The schedulers assign trips from 9-11am local, so what I do is just log on around noontime to check if I've been assigned anything. If you've got the nightime reserve, most of the LA basin flights leave around 7pm, a 6pm show, so I'm all packed and ready at home around 230pm, just in case someone goes sick. If you don't get a call by 4pm, odds are the night time launches are all covered. It is a hard 3 hour call, once I've been stuck on the 405, called skeds to let them know I was stuck in traffic, they said get there as soon as I could, was about 5 min late for check in, pushed on time, never heard anything about it(but I'm sure I've got some type of letter in my file). Have only been called out on 3 hour call 3 times in a year, most of the time its assigned to my via vips. Just check it around noon, and before you got to bed, no worries. Good luck staying awake thru indoc.
