- Dec 20, 2023
- 2024 Carbon Cub EX-3
- CYTZ
- PPL (ASEL)
This winter season, I have migrated from the northeast (Toronto, Canada) to the southeast (Tampa Bay, Florida), and it has been great to have many more VFR days and no need to worry about engine pre-heat and freezing levels. However, there are lots and lots of small grey-white planes hiding in the haze and clouds, and the number of birds enjoying the thermals at 1100 AGL is huge here. Although my rate of spotting other aircraft is not very high, ADS-B gives me a chance, but the birds are in almost every thermal, which are everywhere in the afternoons, other than over large bodies of water.
So I would like to become as visible in flight as I can to all these other flying "objects". To this end, I have been looking at the “strobe” mode of the XeVision XeTREME lights over the “wig-wag” of my current wing lights.
Issues that I see with an upgrade:
Any comments on this project?
- Physical - the XeTREME lights are much deeper than the current lights. From what I remember of the build and the build manuals, there should be enough space behind the current mounting plane of the carbon fibre. Also, I have seen online installations of the XeTREME lights where an adaptor plate was fashioned to move the light unit slightly forward.
- Electrical Power - the XeTREME lights are 100 W continuous, which is more than the current 20 AWG wiring can handle after upgrading the 2 circuit breakers (lights and aux bus). So there appear to be two possible solutions:
- To “double up” the wing wiring where both 20 AWG wires are used in parallel (creating ~17 AWG) for positive, and the wing spar is used as ground. As the wing spar has a large cross-section, the induced magnetic field should be very small and away from the magnetometer.
- Add a 12 Vdc to 24 Vdc converter (~240W) to boost the voltage and halve the current in the wing wiring. This will require a small box (many are available online).
- Electrical Noise - as the switching rate of the “strobes” will be much faster than the wig-wag, it might be wise to add some capacitance (e.g. an alternator filter cap) behind each light on the wing to reduce power spikes.
