Lear70
JAFFO
- Oct 17, 2003
True... as long as the airspeed is constant. If your airspeed slows at a given pitch angle, the AOA will inrease, and vice-versa. As long as the pitch angle is reasonable for that altitude (2-3 deg NU), you'll run out of airspeed and vertical climb rate and start descending before you'd ever stall the aircraft.Rez O. Lewshun said:PTCH is different in that it maintains the pitch angle the pilot sets. This is better than Vertical Speed or Speed mode because PTCH mode maintains a contant angle of attack. The pilot doesn't know what AoA he/she is flying, nonetheless it is constant.
I used pitch in the Lears but I don't like the way the CRJ handles pitch mode, and I certainly don't like the way it handles speed mode (uncomfortable for the pax as it chases its tail all day), so I use vertical speed and just monitor the airspeed.
The one thing I DO use pitch mode for is extending the flaps on a Flaps 20 aircraft, IF I'm descending. The pitch moment is so extreme going from flaps 0 to flaps 20 that you'll set off the trim clacker most of the time, but pitch mode will simply reduce your rate of descent and you can switch back to v/s or speed mode and dial back in what you need. Much easier on the pax...
