Ignition backup battery failure on run up - FX3
Tsquared
CCX-2000
KMIC
Private. Endorsements - Tailwheel and HP
Earlier this summer while performing a engine run up prior to a flight I had the Right Mag emergency backup battery fail.
Video taken after aborting the flight and returning to the hangar
The PS-1221S battery had been replaced in October of 2025 during my conditional inspection. Normally I fly my FX3 about 120 hrs a year, but I am down to about 50 hrs a year due to work, weather and an elderly mom who has needed a lot of care recently. Prior to this attempted flight on June 6th, the plane had not flown for 3 weeks and had less than 15 hrs since January. Whether this is a factor or not, it’s worth noting. Also note the battery had a date sticker of 06/20/25 and this failure occurred on 06/06/2026.
During the run up the voltage dropped to 5.9 before I shut off the RT IGN Battery. I considered this a failed runup and returned to the hangar for diagnostics.
The solution to this was to replace the PS122S battery with a new one. My new SOP will be to replace that battery one year after the battery manufacturing date and not during the conditional inspection time. I have also changed my engine run up check list to include a 10 sec run on the emergency battery.
if you haven't already changed the alerting on for Alternator/Amp to give you a red and audio alert I strongly recommend doing so. This is aligned with what Cactus Charlie recommended in some earlier threads (see the N40DT accident threads and the ignition battery threads).
I’m posting the videos and pictures as most people have never seen (and hopefully never will) this failure before. Hopefully this thread and the other discussions on the ignition system will educate folks and prevent another N40DT situation where the emergency backup system failed when it was needed the most.
You are fortunate if you can be shipped a PS 122S that is within 1 year of manufacture date. Read the embossed debossed date stamp. The sticker was likely not put there at manufacture.
Earlier this year I had a battery fail less than 2 months after if was shipped to me.
I have data for all my ignition batteries used over the last 6 years and it's obvious to me that elapsed time (since built, since shipped, or since fitted) is not a good predictor of current condition.
Read the debossed date stamp.
20241218-JA indicates a manufacture date of December 2024.
The battery in my plot above had date code 20240619-JA. The current battery is a warranty replacement with the same date code. It is performing better.
When I bought my most recent PowerSonic PS-1221S, I found the local distributor with the highest volume and explicitly waited until a new shipment arrived. That way, it was only 2 months from manufacture to my hands. If I had gotten the battery from the cheapest place, then it would have been sitting on the “shelf” for a long time...
That said, I am not happy with the battery’s performance, and I have been looking for a local shop with the right crimp tool so I can rewire the system to run off the IBBS, but it appears that I will have to break down and buy the crimp tools...
I understand Neil modified his system to use an EarthX battery with more capacity and reliability. Is this an option anyone else is considering?
Neil replaced the PowerSonic with an EarthX to improve reliability without changing the system’s behavior. Personally, I see the current default FX-3 design as a legacy leftover from before the Garmin G3X Touch was used with its IBBS. If you have the IBBS, which includes automatic failover, you don’t need PowerSonic or the manual, pilot-controlled failover complexity.
I would not want my ignition on the G3X Touch IBBS. The additional approximately 1.3 A load will shorten the time IBBS is able to drive the DU, GEA, and GSU.
If you had a 6 AH IBBS maybe having one IBBS power G3X and ignition would be viable but I'd still prefer a completely independent emergency ignition power source.
I am no electrical or electronics expert, so this is just my humble "jack of all trades" opinion. IMHO, someone (either CC or some smart person on this forum) should publish a safe, tested solution to upgrade the backup battery system on the FX/EX-3 to match the X/NXCub. From the various threads on this forum, the PowerSonic battery is a known, proven weak point that's begging for a solution. The X/NXCub uses a dual IBBS system where one 3AH IBBS is completely dedicated to the right electronic ignition. It's controlled by a 3-position switch that automatically provides power to the right mag when main battery fails. I've upgraded my NXCub with a 6AH IBBS for the right ignition. The other separate 3AH IBBS drives the G3X Touch. Neal's EarthX solution is a good partial solution, but doesn't make the FX-3 as robust as the X/NXCub.
Anyone here on the forum care to suggest a solution? Maybe with all the various posts flying around I missed here someone detailed a solution. I would have my local avionics shop immediately upgrade my EX-3 if there is a safe, tested solution.
Many thanks!
