weekendwarrior
- Jun 14, 2002
(b) Paragraph (a)(2) of this section does not apply if :
(1) Part 97 of this chapter prescribes a standard instrument approach procedure to, or a special instrument approach procedure has been issued by the Administrator to the operator for, the first airport of intended landing; and
no you couldn't. first of all, which plane could go to the moon and go to a legal alternate with the required fuel reserves and what ICAO identifier are you going to file to on the moon?To answer your question, you can file to an airport without an approach procedure...look at it this way, you could file to the moon if you wanted too!
FN FAL said:no you couldn't. first of all, which plane could go to the moon and go to a legal alternate with the required fuel reserves and what ICAO identifier are you going to file to on the moon?
FN FAL said:To answer your question, you can file to an airport without an approach procedure...look at it this way, you could file to the moon if you wanted too!
