Id 70/75/90/95
Tim47SIP
Serving for the USofA
Well, I need to start using the ID% but don' really understand the dif here. When would you use any one over the other. Obviously the ID95 is the way to go, but I assume they are not always available. I am going to use AA out of DFW. I can't JS as I am on an extended MLOA and am not authorized per the TSA.
Anyone out there have experience with this??
ID = Interline Discount
ID90 means you get the fare at 90% off the highest published Y class fare.
As far as which ones to use, different airlines have different agreements. ID95 is OBVIOUSLY the cheapest.
If you can get a ZED fare, it's usually cheaper than ID's.
Tim, someone is saying on the ALPA board that they were told by the pass gurus at ASA that we are no longer eligible for interline travel (IDs). May want to call the GO and check on that. Not that anyone will actually answer you or call you back.
Confirmed. ASA has no ID90s with any other carrier. This was not a condition in the contract between ASA and Delta; however the two parties are meeting next week to resolve the issue. Details to follow.
And the hits just keep on coming.
Yes, all of you with 300 hours, come to ASA, the airline with the worst work environment, lowest morale, and worst travel benefits in the industry.
Depending on where you are going and what the % is it can sometimes be cheaper to actually buy a positive space ticket then the discounted one. I would do the math on both.
True. With Spirit, Airtran, and SWA offering many double digit fares for positive space, it's often hard to justify the same money for a space available ticket on a mainline partner
Id 50/75/90 have mostly gone away several years ago. Most carrier participate in ZED fare a Zonal fare program which is better than the ID. Price is based on zone milage and is cheaper. Another advantage to ZED fare is that you can use it on multiple carriers with just one ticket. For Example I work for CAL. I buy a ZED fare from DTW to ATL. I can jump back and forth between DAL and NWA on that city pairing because they are part of the ZED agreement. Whoever cashes in the ticket gets paid. With Id 50/75/90 you had to buy a Id on each seperate airline.
Carrier that use ZED. CAl, DAL, NWA, AA(?) A lot of foreign carriers. Aeroflot, Czech Airlines KLM and many more. Parents are elegible to use Zed fare. Domestic and International. You cannot use ZED fare on the Airline you work for must use your passes.
Where do you buy them? Your company's ticket counter?
DAL is not using ZED at this time. website says they might by end of 08..... tuff luck of dat.... bouyyyyy
turbinej's explanation is right on the money. what kind of pass you get will depend on the carrier and the agreement your airline has with it. id75 are pretty much useless... you can get the same price or better by buying a discount positive space ticket... you can also probably get to the same destination on another carrier with a better agreement (id90, zed).
zed's are by far the cheapest and most flexible. most agreements are being converted to zed's as they are renewed.
Confusing!
OK, if AA has ZED's, does your airline have to have an agreement in place with them or are they for anyone with an company ID??
Tim
Tim
Whether it's a ZED or ID whatever, it depends on what the agreement is between YOUR airline and AA.
I don't know who you work for, but go into your company's travel listing website (CAL's Coair, UAL's Skynet, DAL's travelnet, whatever) and it will usually say what the agreements are between the two.
Again, depends on who the agreement is with. When I go into Coair, it says that myself and spouse/dependents get a ZED on whatever airline, but parents DON'T.
What if your airline doesn't have an agreement with the airline that you want to ride on? (a foreign carrier in this case)
