I saw this happen
  • Thread starter Thread starter Weasil
  • Watchers Watchers 8
Weasil
CHI03FA150
HISTORY OF FLIGHT
On June 7, 2003, at 1031 central daylight time, a Cessna 172M, N13474, operated by Illinois Aviation Academy, was destroyed by impact and post impact fire when it collided with the terrain while taking off on runway 28 (4,751 feet by 75 feet, asphalt), at Dupage Airport, West Chicago, Illinois. Visual Meteorological conditions prevailed at the time of the accident. The solo instructional flight was operating under the provisions of 14 CFR Part 91 without a flight plan. The student pilot was seriously injured. The student pilot was practicing takeoffs and landings at the time of the accident. The accident occurred on the third takeoff.
The airplane departed for a dual instructional flight in the traffic pattern about 0930. On board at the time were the student pilot and his instructor. The student pilot was simulating soft-field landings on runways 20R and 20L. The instructor radioed the tower after the second landing and requested runway 28 for more favorable wind conditions. The student pilot conducted a third soft-field takeoff and landing. The flight instructor subsequently exited the aircraft. The student pilot then conducted two more soft-field takeoffs and landings. Following his second landing the solo student noticed the winds had shifted to the south. On the final take-off the student utilized ten degrees of flaps and applied backpressure to keep the weight off the nose landing gear. The student then leveled the airplane in ground effect and the airplane drifted to the right of the centerline. The student applied a crosswind correction and heard the right main landing gear strike an object. The student pitched up the nose of the airplane and subsequently lost control of the airplane.
The pilot of an airplane holding short of runway 33 for takeoff reported seeing the accident airplane at a very low altitude over the airport in a 45 degree nose high attitude. According to the witness the airplane slowed and rolled to the left, subsequently impacting terrain, left wingtip first, and cartwheeled to a stop. The witness noted that the accident airplane caught fire several moments after it came to a stop.
PERSONNEL INFORMATION
The pilot held a student pilot certificate and a second-class medical certificate, which was issued on October 31, 2002. The last medical certificate contained the restriction, "Must wear corrective lenses."
The pilot's logbook showed the pilot had 109 hours of total flight time and 6 hours of pilot in command time. The pilot also had received a 90-day solo endorsement from his flight instructor on April 22, 2003.
AIRCRAFT INFORMATION
The airplane was a Cessna 172M, serial number 17262777. The last annual inspection was performed on July 2, 2002, at a tachometer time of 6,263 hours.
The engine was a 150 horsepower Lycoming O-320-E2D, serial number L-36096-27A. A 100-hour inspection was completed on the engine on May 22, 2003, at a tachometer time of 7,122.2 hours. An engine logbook entry showed an oil change was completed on June 5, 2003, at a tachometer time of 7,162 hours.
According to Federal Aviation Administration records, N13474, was owned by Flying W Leasing. The airplane was being operated by Illinois Aviation Academy Inc.
WEATHER INFORMATION
A weather observation station, located at the accident site, recorded the weather as:
Time: 0953
Wind: 270 degrees magnetic at 6 knots
Visibility: 10 statute miles
Sky Condition: Sky Clear
Temperature: 19 degrees Celsius
Dew Point: 13 degrees Celsius
Pressure: 29.81 inches of mercury
Time: 1053
Wind: 200 degrees magnetic at 5 knots
Sky Condition: Few Clouds at 3,300 feet above ground level
Temperature: 21 degrees Celsius
Pressure: 29.80 inches of mercury
WRECKAGE AND IMPACT INFORMATION
The National Transportation Safety Board's (NTSB) on-scene investigation began on June 7, 2003.
The main wreckage was located on runway 28, about 60 feet east of runway 20R. The initial impact mark was located to the right side of runway 28.
The general path of the ground scarring was on a magnetic heading of about 200 degrees. The main wreckage came to a rest on a magnetic heading of about 280 degrees. Several impact marks were located between the initial impact mark and the location of the main wreckage.
The fuselage from the engine firewall to the tail was consumed by fire. Both wings sustained extensive fire damage and remained attached to the fuselage. The left wing of the aircraft was bent aft 90 degrees. The left flap and aileron were burned away and the right flap and aileron remained attached to the wing. The rudder, vertical stabilizer, elevator and horizontal stabilizer remained intact. Aileron, elevator, and rudder flight control continuity was established from the flight control surfaces and/or bellcranks to the cockpit.
The fire destroyed all cockpit instrumentation, the fuel selector, and all of the engine controls.
The engine sustained substantial impact and fire damage. It was remained partially connected to the firewall, although the engine mounts were extensively bent. The engine cowling remained mostly intact but did sustain substantial impact and fire damage.
The propeller was attached to the engine with the spinner still intact with substantial impact damage. Both propeller blades were bent aft and twisted.
MEDICAL AND PATHOLOGICAL INFORMATION
The pilot sustained serious injuries and was taken to the hospital by emergency personnel.
The pilot had a broken tibia and facial injuries.
ADDITIONAL DATA/ INFORMATION
The FAA was a party to the investigation.
Okay. It sounds like a typical aircraft accident, if there be such a thing.
But you posted it, and you announced it by stating that you saw it. Anybody can read the statistics or the preliminary report. What did you see, and more importantly, how did it affect you? You didn't post this simply because the event occured, did you?
You're feeling something right now, and it's eating at you. Share it, get it out in the open, take advantage of the interaction. More than a few pilots here have been invovled with, or whitnessed an event, or lost friends in one. You're not the only one.
Speak.
"The pilot's logbook showed the pilot had 109 hours of total flight time and 6 hours of pilot in command time."
Another case of a young instructor taking advantage of a filthy-rich kid eager to fly???
Thus the metric system did not really catch on in the States, unless you count the increasing popularity of the nine-millimeter bullet.
-Dave Barry
Dave Barry should move to Mexico, where it is illegal for civilians to possess firearms chambered in military calibers. They have no crime there, the police are not corrupt, nor are the politicians and the water and air are clean.
You really had me going for a minute. I'm sitting here asking myself if there is another Mexico that I don't know about!!!
Hahahaha :D
There are several things which stand out in this accident report. I believe there is a lot of value for flight instructors to read about things like this so they can learn from them.
There is another thread running at the moment regarding an accident in Hickory NC (again a student doing touch and goes). Several instructors made comments regarding what "may" have been unsafe about that operation and were shot down by other people.
Is there any requirement to teach a student pilot touch and goes? No there isn't. There certainly is no requirement to teach soft field landings until the pre-solo cross country phase.
What are the benefits of doing this as opposed to full stop landings? I don't know but what I do know is this.... 100% of the accidents at my company in the last 12 months occured during the takeoff or landing phase of flight. It seems to me that as instructors we should always be teaching students to be as cautious/conservative as possible.
The only solo landing requirement listed in part 61 in fact is to do 3 full stop landings. And why do you think recent experience requirements require you to do your landings to a full stop if in a tailwheel aircraft or at night? Could it be because the full stop portion is considered more challenging then merely doing a crash and go...? Food for thought.
Here's what else stands out to me, the significantly high Total Time for a student pilot. The fact that the student pilot says the winds shifted to the south ( I assure you they didn't, I was landing on rwy 33 at the same time).
What about stalls? Do you teach your private pilots to do complete stalls or just imminent stalls (both are required by regulation but only one is required by the private PTS). Do you take time to also teach them what pitch attitudes to avoid?
For Example, the pilot in this case reacted to a right drift off the rwy and a wheel striking "something" by pitching up to "45 degrees" and applying left rudder to correct for wind drift. We can all see what this resulted in. At 100 feet agl it is more important to drill into a student the importance of never doing either of this things, because there is NO altitude to recover from a stall/ incipient spin.
Here's the other things which raised red flags, the Fact finding appears to imply that this student was soloed by a different instructor and had received a 90 day from the new instructor. As a flight instructor you might want to ask yourself, what training would I do with somebody else's student before updating their solo endorsement? (Please keep in mind that I"m not assuming something was done wrong in this situation, just food for thought).
Timebuilder said:
I noticed the ratio of TT to PIC time also.
ratio aside, i've instructed before, and i can remember students who had 100+ hours of dual, and were nowhere near being a private pilot. infact, i have never been so scared as the first lesson i had with one.
it seems like they're always the crazy ones, wearing AF flight suits to solo the C-150, and carrying a huge set of binoculars around their necks to read the names of water towers when lost.
there is nothing like having to break it to somebody, that they just will never be able to be a pilot.:(
You got that right. Ever had a student threaten to sue you when you told them they were struggling and would spend a lot of money and then threaten to sue you again BECAUSE they spent a lot of money and weren't done?
There's an experience I'd rather not repeat.
By the way, how is it you have instructed when your profile says you are a 200hr PP?
Ya Know I don't post much
Gentelmen,
I am amazed by the profound wisdom of the Message board.
"Ratio of total time to PIC"
What? you never had an "adult" show up for lessons. I have had many 15 hour a year pilots show up at the fbo and need instruction.
Avbug was(a common occurance) correct, a common accident.
You know I have a few hours dual given, not once did someone show up with a "flight suit or binocualrs"
And in my short time as an instructor, I can't recall anyone who couldn't be taught to fly.
Oh wait, yet more, 200 hour, airport cafe experts. Sorry I didn't realize what agust company i was keeping.
Oh Time, Wright, You may or may not have had a chance to Visist Mexico. I happen to live near it, and have traveled in it. Try Guymas, Hermisio<sp> or San Carlos, Guns? well the only guns I saw were on the 18 year old soldiers necks but the beer was cold the women pretty and It is pretty much gringo-ville. meaning my "cerveza por favor" was all the spanish I needed. thankfully.
Take Care
P.S. Beer and flightinfo do not mix
Re: Ya Know I don't post much
I am an "aspiring CFI" and I have instructed, mmOkay?
But Jim Beam works great!
The word you've entered isn't in the dictionary. Click on a spelling suggestion below or try again using the Dictionary search box to the right.
Suggestions for agust:
1. egoist
2. august
3. aghast
4. August
5. agist
6. agues
7. agouti
8. egoism
9. egos
10. arroused
11. accost
12. Aust
13. egoists
ouch
Thanks for keeping me honest.
Me and Jim Beam parted ways yeas ago...actually on the road from memphis to millington.
But Dewars and I have a nice relationship.....
Take Care
No, not okay.
Teach students full stalls? Yes, absolutely. Teach students touch and go landings? Yes, absolutely. A student should be able to do both.
I would never solo a student who couldn't confidently do a touch and go landing.
One would be insane to do otherwise. Surely you teach a student to go around, don't you? But you don't teach them to go aroundon the runway? That's a touch and go landing...and the student had better be able to do it.
The only time I will insist on a full stop with taxi back is after a power off approach, and then for the sake of the engine, not hte student. Otherwise, only if the student needs a break, the time to talk, runway conditions require it, etc.
How many accidents has your company seen in the past year? There's not a lot to hit in flight, but the ground is everywhere, and you stand the greatest chance of hitting it when you get close to it. In my limited experience, this happens at least twice on each flight; usually close to the time you're planning on landing, and frequently about the time you take off. Seems that landing and takeoff accdients might be more prevelant...especially for an operation involving people who are just beginning to learn, instructors who are too young to have opened their eyes yet, and constant trips around the pattern. But that could just be a guess.
Wanna bet? Perhaps you're just teaching the recoveries wrong. After spending a great deal of time never climbing above one hundred feet while in flight, and operating on the edge of a stall and in and out of the stall while performing steep turns at that altitude, I'd have to disagree...but then I'm still learning (as are we all).
I certainly don't recommend teaching students to recover in this distance...but as an instructor one should understand that it can be done, in case on ever needs to do it. Too often instructors frighten students into their graves by creating a lifelong fear of slow flight and stall recoveries...those mind-bending pushovers that leave the student feeling as though their testicles are floating by their adams apple, in a dramatic effort to recreate some great moment on a microsoft flight simulator. Why can't instructors teach stalls with the nose below the horizon, and recoveries that truly involve decreasing AoA one degree...instead of 30?
A frightened student doesn't learn, a frightened student makes mistakes when the chips are down. A frightened student does as the one in the accident report did. But don't blame that on a touch and go landing, or the use of full-stall training by the instructor.
Where is this only solo requirement located?
Do you not understand why full stop landings in a conventional gear airplane are required, where in a nosewheel airplane, they are not? It has nothing to do with challenging, or otherwise. In fact, a touch and go can be more challenging in a conventional gear airplane. How does this apply?
Have the regs changed since my last instructor gig? I thought the holder of a student pilot certificate can only log "dual received" or "solo". Solo is not PIC on a student pilot certificate.
Denizen said:
Gentelmen,
so i may have a few more than 200hrs.
this accident report just reminded me of a couple of the stand-outs of my years in flight instruction.
in general, it is very rare that somebody CANNOT learn to fly, but it happens.
wasn't trying to amaze anybody. ...back to the cafe.
105VIKING
Nobody's mentioned it so I will. How can a student pilot have 6 hours of PIC time? We all know pre-private solo time is not loggable as PIC.
Next, this hasn't evolved into a large pro/con touch-n-go discussion but I'll put in my two cents. I found that it just depended on the student. Some handled the higher situational awareness required to touch-n-go better than others. Hence, most students I soloed I instructed to touch-n-go but others I had do only full-stop taxibacks.
Dude
