How is it possible to fly inverted???
Thedude said:
Speed is important, but I assume that for disscusion purposes we are talking about steady state flight, straight and level. So descending while inverted would negate your argument. That is not flying inverted that is descending inverted.
The short version is CL=1/2 Rho V*2. So according to this, I can shove a rocket engine in my car and fly it around because I have now acheived V=velocity. I am talking real world , make it happen and show me kinda physics when I speak of the 152. Not enough thrust = not enough velocity.
Region of Reverse command is not mysterious regime. Every time I land my B-727 the approach is done in the area of reverse command as you will find with most transport cat a/c.
Descending while inverted does ont negate my argument, since it wasn't based on that. I said IF you don't happen to have enough thrust to overcome the drag, (do you know if that would be the case? I don't) then you can add to your thrust vector by descending.
Cl does not equal 1/2*rho*V^2 (I assume you meant to use use * as an exponent).
Cl = L / ((1/2)*rho*V^2*S)
or,
L = Cl*(1/2)*rho*V^2*S
Like I said, if you don't have enough Cl, you can make up for it with V. (Even in a descent. Getting some of your weight to add to your thrust does not mean that a wing is "not flying" anymore.) Which brings me to my next point. You implied that with an inverted airfoil, the only way this can work if you add some ridiculous amount of V to make up for a miniscule Cl, as per your car/rocket example.
Thanks but no thanks... let's do some actual investigation. Let's look at the airfoil data obtained expirementally by NACA in the 50's* for a sipmle cambered airfoil. Say, 2412 for example. In the positive AOA range, the Cl tops out at about 1.6, and in the negative range, at about -0.9, so the negative Clmax is about .56 of the positive. To maintain the same lift we'd have to multiply (V^2) by the reciprocal, or 1.77. The square root of that is about 1.33. Blah blah blah, get to the point? For an infinite NACA 2412 airfoil, stall speed increases by .33** if you invert it. Do you need to strap a rocket engine on to do be able to do that? Don't think so.
* Reference: Introduction to Flight, John D. Anderson, Jr. I tried to look for this stuff online, but couldn't find it. If you want, I'll scan the graphs for you.
** Incidentally, this means you big jet jocks can still fly almost the same approach speed inverted as upright, you just can't flare. :D
After y'all get through beating each other up over conflicting formulas for lift generated by airfoils, you can branch out to lifting bodies, and then sustained knife-edge flight.....:D
mzaharis said:
The argument that the air goes faster on top to match the air that takes the shorter path on the bottom is grade school fiction.
I'm surprised to hear that. That is exactly what is presented within my textbook. Can you really say that this theory is false???
PFM, it has to be PFM....
http://http://www.lerc.nasa.gov/WWW/K-12/airplane/foil2.html\
Visualize and understand.....or at least help.
I love this thing, at least it helps me visualize whats going on. By changing the camber and the AoA, as well as the thickness, it makes it easy to see how the pressure differential changes.
Remember, the yellow line on the graph is the lower surface, which is generally greater than the free air stream. Magenta is the upper surface, the critical surface for producing lift.
Yes, based on direct obervation. The top and bottom layers simply don't rejoin when lift is created.
http://www.amasci.com/wing/airgif.html
Here's a question for everyone who disputes bernoulli's principle as the prime generator of lift.
How can an aircraft fly at a negative angle of attack and still develop enough lift to sustain flight?
Most WW2 fighters (probably modern day fighters too, but them are the only ones i know for sure), including the spitfire, flew at around -0.5 to -1 degree AoA in steady flight, because the Coefficient of Lift was still positive at that point thus still producing lift. Only chambered airfoils can do that. Symmetrical airfoils have their "angle of zero lift" at the 0 degree AoA point.
Therefore i conclude (and you conclude however you want), that the 'induced lift' theory (or newtons third) can not be the prime generator of lift. If you have a negative AoA, how would the relative wind strike the bottom surface of the wing and push the airplane up?
On the other hand, with a chambered airfoil at a negative AoA but still with a positive Coefficent of Lift, bernoulli's principle makes only sense. The airflow above the surface speeds up, thus decreasing pressure. The high pressure below the wing tries to 'unite' with the low pressure above the wing and therefore produces an upward force.
I did a quick search and came up with the following website: http://www.centennialofflight.gov/essay/Theories_of_Flight/Two_dimensional_coef/TH14.htm
Didn't read through everything, but it should prove helpful.
I'm not saying it. The guys who designed the wing on they airplanes you fly say it. Most non-aerospace engineering textbooks apply a hackneyed version of Bernoulli, based on the "equal transit time" concept. It has been conclusively proven wrong since the earliest wind tunnel tests. It gets trotted out as a layperson's explanation for lift because it (incorrectly) uses some valid fluid mechanical concepts to provide an easy-to-understand explanation. Therefore, you see it in many non-engineering texts. While Bernoulli's equations do apply to the flow field around a wing, it is not that the air is uninterrupted prior to arriving at the wing, the air below the wing goes straight, and the air above the wing curves. There's a much more complex flow field around an airfoil than that. Especially for subsonic flight, the air in front of the wing is actually travelling in an upwards direction, and the air behind the wing is travelling in a downwards direction. This is called circulation, and is the fundamental property of airflow around a wing that defines how lift is generated.
Read the link, as it explains circulation theory of lift far better than I can. It's a pretty long slog, but it describes the basic principles behind what airfoil designers such as John Roncz and Michael Selig use in their analytical tools to design airfoils. The "air has a longer trip on the top of the wing than the bottom" stuff is what gets presented in non-aviation and general aviation textbooks, not academic aeronautical engineering textbooks. It is just not a full explanation that explains the full flow field around the wing.
I'd try to explain it here, but in my opinion, the author of the website used just about the minimum number of words and pictures necessary to explain the concepts, and they are far too much to post here.
http://www.av8n.com/how/htm/airfoils.html
BTW, the Coanda effect is also incorrect, as it only applies to an energized stream of air flowing over a curved surface. The airflow over a wing is not energized, unless you're referring to an unusual STOL design such as the Ukranian AN-72 or the US YC-14 prototype STOL transport, which uses engine exhaust to energize the overwing airflow.
http://www.av8n.com/how/htm/spins.html#sec-coanda
BTW, the parent website for these pages is a fantastic resource for the aerodynamics and physics of flight. It takes the principles used by aerospace engineers to design aircraft, and presents them in a manner that makes them useful to pilots, without "watering them down" too much.
When I was back in high school in 1983, I was able to do a summer research experience program at University of Iowa's Fluid Mechanics Lab (I was SUCH a geek - oh, wait, I still am). I had a fun time working with a FORTRAN program that did pretty much the same thing as FOILSIM, but without all the pretty real-time animations. It had been written by a grad student as his thesis, and contained considerably more advanced math than I understood at the time. It took airfoil coordinates, and determined the pressure and velocity distributions based on a circulation theory of lift model (and the circulation vortex to satisfy the Kutta condition! - google it ;-) ). That's when I started to learn that what's taught in high school textbooks and popular aviation books was either very incorrect or very incomplete.
As a student pilot, I REALLY want to at least know what keeps the aircraft from falling out of the sky. What was mentioned above is basically what I've read in a number of textbooks. Not only have I read this information, the principle does seem to make sense, and I will get quite confused if anyone disputes the theory stated above. The "low pressure" idea is really how I prefer to look at it. It works the same way in a carburetor. Fuel is literally lifted upwards from the float-bowl despite gravity. Air rushing through the carburetor throat creates an area of low pressure, thus allowing atmospheric pressure to push the fuel upwards. I respect all opinions in here, and the fact that I'm just a student. Nevertheless, I respectfully do not understand how this theory can be disputed, even though it may not be the entire factor contributing to the production of lift.
Conceptually, that is more or less what's going on, and that is a good place to start. Just understanding that, by decreasing the cross section of a flow, you speed up the flow and decrease its pressure (the basics of Bernoulli), you have gained an aerodynamic understanding that escapes most people. It's just that you have to go through a few more layers of detail to see how it ultimately results in lift on the wing, which is a much more complex process than what can be communicated in a couple of paragraphs in a web forum. Unfortunately, most non-aerospace engineering texts omit those layers of detail, and end up with an explanation that, while flirting with a few truths, is inaccurate.
Some worthwhile links have been provided by some others and myself. Print them out, spend a Sunday morning reading them over coffee instead of the morning paper, and you may soon know more than your instructor regarding teh aerodynamic mechanisms for generating lift (just don't tell him that! ;-) )
True that there's a higher speed and lower pressure, but if the higher speed causes the lower pressure, then what causes the higher speed?
BTW, if you want to really bake your noodle, go to the source. The definitive source book on airfoil behavior is a book called "Theory of Wing Sections" by Ira H. Abbott and A. E. von Doenhoff, a couple of NACA scientists (not NASA - it was written in the 1949, I believe, when people didn't think of space travel - NACA stood for "National Advisory Committee for Aeronautics", and was the precursor for NASA). It was probably on the bookshelf of the guys who designed your airplane's wing. It is still a must-read for all aerospace engineers. It was the first textbook to really describe in detail the behavior of airflow around an airfoil.
It is EXTREMELY mathematical by non-engineering standards, but it also has a great many useful charts describing the lift behavior of numerous symmetrical and cambered airfoils. That alone makes it worth the $13.97 it costs. If not, find a local university engineering library, and there's a good chance that they'll have a copy, particularly if they have an Aero E department.
http://www.amazon.com/exec/obidos/ASIN/0486605868/qid=1097121280/sr=2-1/ref=pd_ka_2_1/103-1791045-7591024
EDIT - The book, while written in 1949, was re-released in 1959, after NASA was created. Therefore, you will see some references to NASA in all contemporary versions of the book.
Check this out, I think you'll like it. Except it's pretty clunky... to enter an airfoil other than the default NACA 0012 (just click "compute" twice) you have to go to the Examples section, copy a set of coordinates, and paste it into the applet (be sure to click "clear" first.)
Thanks. It's well past my bedtime (wife's in bed, grumpy that I'm typing away - stupid me), but I definitly will get around to playing with it. Thanks for the heads-up.
If you want a really good database of airfoils, go to the University of Illinois Applied Aerodynamics Group's website. This site is maintained by Michael Selig, one of the world's best low-speed airfoil designers.
http://www.aae.uiuc.edu/m-selig/
An interesting article on Selig
http://www.uiaa.org/urbana/illinoisalumni/utxt0202b.html
Vnugget,
The world may never know. Actually, I'm only kidding. I think many of us understand circulation theory. Place a rotating sphere or cylinder in a fluid and the velocity of the fluid in the direction of revolution moves faster, sorta like walking in the same direction as a moving walkway. The flow in the direction opposite to the revolution is slowed, like walking against the walkway. This produces lift on the object through the Magnus effect. But most wings don't have this type of circulation about them in order to impose the velocity differential.
The greater the camber of the wing or higher the AOA, the greater the velocity increase over the wing. The change in camber is a change in direction of the airflow, which implies an acceleration. Now an acceleration doesn't necessarily imply a change in the velocity magnitude, it could be just a change in the direction of the flow. So maybe that's not the answer. But wait, doesn't the top of the cambered wing sorta look like the bottom half of a venturi throat? In other words you take a pipe that narrows then expands, but only take the bottom half. You're still narrowing the flow of the air over the wing more than beneath, hence an increase in velocity. As I mentioned before I'm a physics and engineering guy, but my expertise is not aerodynamics and I'm trying to learn so please refute any glaring inaccuracies.
Dave
That is exactly how it was explained in my adv aero class, and i find this to be the most plausible answer.
That's good to hear. For the first time in a while I thought about the question after reading Vnugget's post and tried to think of all the physical reasons I could for why that was the case.
Dave
Mr. Cole said:
Vnugget,
Dave
Actually, that was also what was going through my mind, but I had a brainfart and was thinking about it backwards, myself, when I asked that rhetorical question.
Blah.
Chris Carpenter, in Flightwise, does a nice job of explaining what causes the air to accelerate over a wing. Chris is the head of Aerodynamics at the Royal Air Force College, and wrote the Flightwise books to aid students who had undergrad degrees in fields outside of Aero to understand the field. He also wrote them such that one can understand them even without a significant mathematical background (he designed them so you can skip the math in the text without losing the ideas). Flightwise is probably the best set of books I have seen for a complete understanding of the concepts without getting a degree in the field, available thru www.amazon.co.uk (not on the U.S. site for some reason). Shipping is very inexpensive thru the Royal Post. Two books, first is basic Aero, the second is all about Stability and Control. Well written, not dry, and he is very good at putting the concepts across. Good for those that want to know "why".
For pure Aero types, hard to beat John Anderson's books to really be able to crunch the numbers (mentioned earlier).
Mr. Cole said:
Vnugget,
Dave
Actually, wings DO have circulation. It is just that it is not as intuitive. This image represents a wing without circulation (Kutta condition not satisfied). This wing is generating no lift and represents how the airflow around a wing would be if air had zero viscosity:
http://www.av8n.com/how/img48/nocirculation.png
A pure circulatory flow looks like this:
http://www.av8n.com/how/img48/circulation.png
Sum the two, and voila, you get the classic flow pattern seen around an airfoil, which sastisfies the Kutta condtion (which, in effect, says that a viscous flow cannot "turn the corner" around a trailing edge, like a theoretical inviscid flow would).
http://www.av8n.com/how/img48/normal.png
In regards to the "chicken and egg" posed by vnugget, aerospace engineers talk of a "starting vortex" that begins the circulation. Some people argue that this is a mathematical obscurity, borrowed from electromagnetic theory (most notably the author of the interesting book "Stop Abusing Bernoulli"), but others would argue that it is a real physical phenomenon.
The website of the author of "Stop Abusing Bernoulli"
http://www.geocities.com/galemcraig/
From that website, an interesting reason why we get the incorrect explanation in so many sources:
Dr. Theodore Von Karman, a most prominent aerodynamicist in mid-20th century, once told his assistant: "When you are speaking to technically illiterate people you must resort to the plausible falsehood instead of the difficult truth."
Once again, my favorite description of lift phenomena:
