How do airplanes turn?
Almerick07 said:
His answer seemed pretty clear stating the ailerons deflect the airflow either up or down either increasing or decreasing lift and they worked together to roll the airplane. He said he drew it, used a model airplane but the examiner wanted to hear the terms angle of attack and camber.
He was failed on the premise of lack of instructional knowledge by using the term deflection, the examiner said it confused him because he thought of ping pong balls. My buddy said he got a little into a changed horizontal component of lift and what not but wanted to keep it simple because the examiner said he was a student pilot.
My guess is that the discussion didn't go:
EXAMINER: How do ailerons turn the airplane?
APPLICANT: Ailerons move up and down, deflecting the air like this pretty picture and airplane indicate, and the airplane turns.
EXAMINER: You fail. You didn't say "camber" or "angle of attack".
My guess would be that the examiner asked several follow-up questions to try to get the applicant to use these terms, and the applicant just didn't pick up on it. I used to update my Jepps on the opposite side of a very thin wall from an examiner's office. It always amazed me what hints he could give as to what he was looking for, and the applicant still didn't pick up on it.
Not that I ever had this problem, mind you...no...uh-uh...well, maybe that time that he asked what equipment I needed for night flight, and he dented my head with his 2-d-cell Maglite before I figured out that he wanted me to say "flashlight" ;)
Fly safe!
David
Appearantly all his follow up was....I dont understand, that is confusing, I am not getting this. I wasnt there and stories tend to get a bit skewed after a while but I know this guy and seems like how he explained it was pretty simple and clear.
I would have told the examiner to find a new interest outside of aviation and next task please
UA-RESURRECTED said:
you should never fly a prop-driven aircraft across the equator. Once you're on the other side, you will lose all thrust and will fall out of the sky.
If you're in the northern hemisphere flying south towards the equator, you should stop trimming the nose down to follow the curvature of the earth. This will cause you to go beyond the gravitational pull of the earth, thereby negating the coriolis effect and replacing it with coriolis force which, as we all know, is the anti-clockwise reversal of the coriolis effect. This will keep the prop turning in a clockwise direction so you can trim the nose down and continue on the other side of the equator.
I'm so lost here
:beer: anyone?
-mini
NYCPilot said:
Yum. Pilsner Urquell. Great beer...I know a place in Park Slope bklyn where they've got'em for only $4 - compare that to $6 a piece in Manhattan....and thats at a dive price.
I know a bunch of places in the Czech Republic where I can get it for $1.00 per pint :beer: . The scenary is much nicer at those places than in Manhatten as well.
And everybody should know that the right way to make an airplane turn is to fail an engine on the side you want to turn towards :D .
TP
If you're ever around LGA in the warmer weather, there's a place nearby in Astoria called the Czech Beer Garden. It has a large outdoor seating area with picnic-type tables surrounded by tall concrete walls. They serve cheap pitchers of beer and they've also got a hamburger and hotdog stand inside as well. Prices are truely reasonable and you can knock off a few pitchers of that Pilsner too.
http://queens.about.com/od/eatingout/gr/bohemian_hall.htm
I knew I missed that scenerio on my private written! You are correct. Anyone know what causes left-turning tendencies???
Bump!
bump, so that I may find this thread at the top of the general section! Plus it's a pretty funny thread!
eP.
