Soverytired
- Jan 30, 2006
When a pax dies or goes to the hospital, that is a death or accident that happened on your airplane, and could wind up following you, via your faa file (not to mention your conscience) for life.
Not "could" . . .it most certainly will. You'll be lucky to have a job and/or a license when the dust settles and the body is buried. There's also a good chance at civil litigation against you personally that will wipe out any assets you have left.
The FAA issued an advisory circular that basically said that a plane that had inadequate ventilation needed to be deplaned in no greater than 30 minutes.
http://www.airweb.faa.gov/Regulator...B0005CDC20?OpenDocument&Highlight=ventilation
This is the sort of thing you'd better have decided before you ever board, because this is the kind of "creeping problem" that can sneak up and kill one of your passengers as you wait just "10 more minutes" to take off.
For example, I think you could very easily say that a CRJ200 with no APU on a 105 degree day in PHX has no significant ventilation. Plan on 20 minutes, MAX, to get to the runway. If you can't make it, declare an emergency and head back.
No company in the US would have the balls to fire you for exercising emergency authority to evac an airplane that was 120+ degrees in the back.
