FN FAL said:Why would you cross feed FROM the blocked tank?
I hear ya, the guy who posted above answered mine...makes sense to me.minitour said:Beats the hell outa me...that's why I'm asking the dumb questions.
-mini
Milwaukee Bucks' plane makes unscheduled stop in Michigan
GRAND RAPIDS, Mich. (AP) -- A Midwest Airlines jet carrying the Milwaukee Bucks and other passengers made an unscheduled stop at Gerald R. Ford International Airport after ice developed in one of its two engines while flying at 20,000 feet, an airport spokesman said Tuesday.
The airplane, which was carrying 74 people, landed at 11:50 p.m. EST Monday, Bruce Schedlbauer said.
The passengers eventually were loaded onto another aircraft and continued their flight to Milwaukee, departing around 2:30 a.m. Tuesday.
Schedlbauer said the engine sustained damage, but he described the landing as precautionary, rather than emergency.
The Bucks were flying out of Cleveland after losing 89-86 to the Cavaliers.
hyflyt560 said:I agree with Satpak. All of the army C-12 pilots I've flown with say "Hot five" and mean the pitot, stall, and fuel vent. As a unit, we turn on the windshield at 10k, unless needed earlier. In the civilian 300 I fly, we say "Hot six" and this includes the probe heat. I asked our mechanic about it and he said because the probe heat gets hot enough without airflow it could be damaged. I asked the same question of the army contract maintainers and they said it doesn't get hot enough on the ground to worry about. It's never failed.
Our C-12 and the civ. 300 I fly have had a total of 4 windshield replacements in the last 4 years. We were told there was a rash of failures of King Air windshields from PPG from certain manufacture dates.
For what it's worth.
FN FAL said:I hear ya, the guy who posted above answered mine...makes sense to me.
Speaking of ice, this just hit the news. Kind of reminiscent of that Spirit incident a few years back...
flint4xx said:There is a difference between a technique and a procedure. The before takeoff section of the POH says "Anti Icing-As Required". Saying "hot 5" and turning on whatever you want is a technique, and maybe be a good one at times. I've seen enough techniques turn into "procedure" without any real thought going into it. And there is always the "that's the way we've always done it" mentality that may factor into this. If you default to the POH, "as required" notation, then just do what is right for that flight. I wouldn't turn on any of it for a local flight around pattern in Cancun for example.
Personally, I wouldn't use window heat unless it was required for visibility. it provides no impact protection, and will only cause premature wear and tear. There are over 6000 KingAirs out there, and every now and then a windshield fails just like every other component. You would see an AD to use window heat if that was a real problem in the fleet.
asolo said:I My theory is that if you decide to put any anti/de-icing devices on is that it is all or nothing. If you are concerned about ice on the pitot, fuel vent, or stall warning you should also be concerned about props and the winshield.
