Horizon Interview Prep
ferrell18
Member
Has anyone here done the Horizon interview prep at ATC in Seattle? Just curious if you thought it was worth the money. It seems that alot of people have problems with Horizons sim session in the interview and this sounds like a good prep but not sure if it's worth $500. Any thoughts?
I would just get a few hours in a Frasca and review the stuff on aviationinterviews.com and you should do fine.
I was thinking about going to Hillsboro and using the Frasca over, I live in Portland so the sim that Horizon uses is real close. Just wasn't sure if ATC did something special that made their prep better then just going to use a Frasca with an instructor that may not be up on Horizon gouge.
You've answered your own question. Nothing special about ATC gouge. HIO Aviation gouge is probably just as good, but cheaper, plus you'll be using the same machine, in the same setting. Good luck.
