Bronco Buster
Active member
- Aug 28, 2006
i just did an oil change and filter change on my 68 PA31 with Lycoming TIO540C engines. When I did a run up with the cowlings off to check for leaks the left engine oil pressure was normal, but right was in the yellow at idle and when I increased throttle it would go into red. Oil was at about 60F when I put it in. I let the engine run for4-5 minutes and recycled the prop several times and pressure did come down somewhat, but it was still higher than normal. Any ideas? My mechanic and I are stumped. Thanks in advance.
Vince Collazo
lvcd@sunlink.net
Vince Collazo
lvcd@sunlink.net
