Hey WN Guys..
OPECJet
1700
Total Time
5K
How much crosswind are you guys allowed? Also, how do you factor the gusts?
Thanks!
johnboy99
Total Time
8000
Thanks!
That's an easy one. You multiply the taxi speed of a Southwest 737 (40-60 knots at most airports, maybe V1 minus 5 knots if its the last leg) and divide it by the square root of how many drinks the cockpit crew had at the bar the night before.
MOCO
Member
35 knot demonstrated crosswind.
As for computing speeds, add 1/2 the steady and all the gust, not to exceed 20 kts. For example 350@12G20 would equate to a target speed increase of 14 (6+8). In calm winds you only add five. Hope this helps.
jetdawg
Total Time
9500
Is that with or without your AT's?
For FL the autothrottles take the gust, when going manual you do the fancy calculations.
OPECJet
1700
Total Time
5K
Thanks guys.
gearup5
Total Time
11000+
yeah the new calculations here are stupid. Watched a guy plant it on hard while the auto throttles "handled it"
johnsonrod
Total Time
8000+
Use the following formula courtesy of Will Farrell:
The angle of my dangle is inversely proportionate to the heat of my meat.
That should work for you.
75 Driver
Total Time
30,000
A 737?
How can you not grease a 73 on everytime, it is the easiest airplane ever built to land.:rolleyes:
Grey Ghost
God Bless America!
Total Time
32500
who cares? i hope you can finally sleep at night knowing this information!
frog_flyer
Caucasian Male
Total Time
rising
CLASSIC!
Jetjockey
Stay thirsty my friends
Total Time
18K+
Classics, (200, 300, 500) yes.................800 & 900 series not so much.
