• NC Software is having a Black Friday Sale Event thru December 4th on Logbook Pro, APDL - Airline Pilot Logbook, Cirrus Elite Binders, and more. Use coupon code BF2020 at checkout to redeem 15% off your purchase. Click here to shop now.
HELP!! Need suggestion on data roaming plan that can be used globally.
Yohei-San
New member
Hello guys,
So would you guys have any suggestions on what sim-card that has a wide data roaming coverage as I frequently travel overseas and my local telecommunication company charges very expensive and VERY LIMITED coverage and data.
I’ve also considered to buy sim-cards at the particular country I went but the hassle and inconvenience to change the sim-cards and topping up is not very appealing for me.
Thanks !!
teddy619
New member
Hi MrYohei,
What I do normally is buying each SIM card from the destinations that I normally go. I have a pouch to keep all my SIM cards, and whenever I fly to that country, I will change to that SIM card so that I do not need to buy a new SIM card again. DO NOT USE YOUR CURRENT SIM FOR ROAMING - I have tried for the first month and I literally cried after I see my bill. :bawling: Hope my answer helps.
Herbert
New member
Total Time
7865
Hello San, definitely this is a big issue, but there's no much to do but buying a local sim card at each place you go. I think you will find some stores in each airport you go. That's the best way for you to have roaming and save some money... The hassle is when you can not buy a local sim card (it is only sold for locals, or so on..)
Or you can use public wifi as well.
Regards.
Pendragonian
New member
Heyyy there Yohei-San, I definitely understand and empathize with the struggle and difficulty that you are facing L
But fortunately I have a possible solution for you which is Flexiroam !! Extra good news is I heard you can REDEEM 1GB of Data for Cabin Crew such as yourself.
Do check it out here: http://bit.ly/2IJCVg3
