Help me figure out how to make this work
Our ops specs don't allow a contact approach, but I'm pretty sure that it requires 1 mile reported visability.
I'm curious if anyone has actually launched on a short flight based on a metar that is better than the TAF. I can see in the regs where there is a little wiggle room, I can also see where an uptight fed would say no way. We have dispatch go shopping for a better TAF in those cases
I had a similar situation going into SFO. Fog rolled over 28R as we were inside the FAF and under the 2000' overcast and tower said, "RVR 28R now 1000, state intentions". We could see all the way down 28L and requested it and were cleared to land. The fog hit 28L just as we rolled up to Tango. Glad we weren't 30 seconds later on that approach.
I've heard of bust (SMF) when guys landed after the RVR went down below mins when they were inside the FAF and it dropped below mins as they were about to land.
If you're inside the FAF and the weather drops below mins, you are still legal to continue the approach to the MAP. IF at the MAP you have any of the legal visual cues to go below DH/MDA, you can continue to land, assuming you also have all of the other requirements met for landing.
We cannot do contact approaches based on our OP SPECS.
So you are flying for a 121 airline into an airport with two parallel runways, call them 17L and 17R, with the control tower in between them. 17R has an ILS and RVR and is currently reporting RVR below your mins. The tower is covered in fog too, and therefore is reporting viz of 1/4 mile. You can clearly see that 17L is completely in the clear. 17L has a vor approach with viz mins of 1 mile, but no RVR reporting. As a 121 carrier, how can you land on 17L?
Some of my ideas:
Cancel IFR - can't because viz is IFR
Circle from 17R - can't because circling viz mins are above 1/4 mile
Fly VOR approach - can't start approach with viz reported at 1/4 mile.
This happened to us; we got the RVR we needed on 17R, but we discussed our options while waiting for that and couldnt come up with a legal way to use 17L. Any ideas?
You haven't landed yet?
Depends on the approach mins. Trends do not carry weight with the FAA. No-go on 3585 since it's below in the TAF main body.
121.613 Wx reports and forecast, or any combination thereof, indicate that the weather conditions will be at or above the auth. minimums (Ceiling and Vis) at the time of arrival.
Wx reports OR forecast...
At XJ: Destnation landing minimums are determined by the visibility requirement of an available instrument approach at the destination airport.
How about this:
TAF has quarter mile in the main body for ETA.
Metar is reporting 1/4 SM, RVR is reporting 2000RVR.
Can you dispatch?
You can dispatch 0/0. Just file from your dep. to where ever you have your required wx via where ever your trying to land. Then when you get over where your trying to land hold till you dont have the go juice to hold any more. Happens all the time and legal, though I bet someone here will disagree. So for that guy... to divert no wx required just minimums to start the approach. If you get the mins while your holding shoot the approach. A friend of mine gets filed BFI to BFI via ANC all the time.
