ToiletDuck
Ninja
- Apr 23, 2005
I've only used the Bose X. What makes the QC2 so good? Superior?
We are looking into TSO certification, but our roadblock remains the fact we don't own the QC2. Bose doesn't want it TSO'd, obviously. One of the criteria for TSO certification is that the headset will still function without battery power.
Running a QC2 out of battery power would be like running the airplane out of gas, in my opinion. There's planning required, you monitor inflight, and there are ample warning systems to back you up. There's no excuse for running a headset out of battery power. If you're trying to save a dime, think of another way.
There is no FAA requirement for a pilot to use a TSO certified headset, unless that pilot's air carrier requires it. There is confusion on this issue because headsets and microphones installed in a commercial aircraft must be TSO'd, they're part of the aircraft MEL/CDL. What a pilot brings to the cockpit is his call.
I have had far more FO's miss radio calls and have issues with their headsets with the Plantronics MS50 and Sennheisers than I ever saw with a UFlyMike. There was an issue with the first generation UFlyMike where the retaining o-ring was too small. We changed to a more robust o-ring in late 2005, and there have not been issues with the unit unplugging, unless there's folks out there who never sent their early adapter in for a retrofit.
Mike
UFlyMike LLC
In your opinion, what is the likelihood of the current setup being TSO'd? As of March or so, I won't be able to use mine at Alaska. It's a dang shame!
I use these
http://www.clarityaloft.com/
They offer almost the same reduction as the Bose but for a guy like me with elephant ears they dont squeeze the head. Not for every one though you have to not mind the earplugs.
Sound quality and ANR is much better with the X. QC2 is a cheap alternative by a couple hundred bucks.
