capt601 said:This still does not mean anything. Any manufactur or campany can give whatever numbers they want - look at the numbers all of the manufacturers give for departing ASE. You know they work the numbers for the one case out of a 1,000,000 that they can actually do what they promise (which of course never happens in the real world, but the owner sees it and the ego driven pilot is too stupid to say it really can't!)
So the numbers that aviation partners put out may work for the trip with no problems, but are they publishing the numbers that take into account the fuel needed to return or go at your ETP's. Most likely they are not! With their numbers you may land at PHOG with 2050 LBS, but if you have a depress at your ETP are you really going to have the fuel to make it or are you floating shark bait?
That is what your flight planning is for, and if you have a wet foot print because you lost presurization then you cant go.... 90% of the time you can do it. In the Last 8 year the company I work for has been doing Hawaii in an 800XP without winglets, we have only had to change to a larger airplane twice. You always do all three ETP calculations be for you leave, I thought that was a given.
