Stealthh21
- Jun 27, 2005
ultrarunner said:Those numbers are right on for .78 HSC. A touch more if you took off above 22k or so.
Yeah, thats where I fly it. You know at 410 how annoying that rumble is.
Years ago when I was flying a Lear 35, we had one of their test pilots in recurrent. We asked him about the minimum altitude for fuel dumping. He mentioned that during certification they conducted high-speed, low-altitude passes down the runway and the fuel was evaporated before it hit the ground. True or not, that's what we were told.p3hawk said:I would recommend and altitude of at least 7000 ft in order for the fuel to properly evaporate.
kilroy said:Typically we figure 1800# the first hour and 1400-1500 the second hour I have seen as low as 1100# per-hour at Fl430 cruising .78.
On high speed climb out we usually do 300 IAS then transition to .78 in the climb this still gives us 1500 FPM in the upper 30's.I have also seen .80 in the climb at 1500 VSI in the mid 30's
If we really want to get high fast we'll target 280 Knots and transition to .70 this usually gives us 4-5000 low FPM thru the 20's and 2-3000 FPM thru the high 30's
Stealthh21 said:Yeah, thats where I fly it. You know at 410 how annoying that rumble is.
GREAT LAKES said:Stealth,
Let the wings get below 900lbs each before going to gravity. No rumble.
Ultra, would you mind going into a little more detail and explain what your theory is behind that. sounds like you'r eon to something and I'd like ot know more about it. Thanks and I look forward to hearing more.ultrarunner said:750 is better, in order to keep wing-fuel warm.
