Hawaii in a "X"?
NW Flyer
So, our flight department is considering a Citation X. One typical mission would be from Seattle to Hawaii.
Can any of you seasoned "ten" guys (or gals) give me some insight on this trip?
---Are we going to run into a wet footprint?
---Will we have to run down to Cali for a fuel stop?
---Should we be looking for something else?
Only flew HI in the X a few times. Each time we flew to SFO 1st for fuel.
Flew at max speed each time.
Where were you coming from? Did you stop in SFO because it was on your way, and you had already flown a while to get to the west coast? Or, were you coming from the PNW, and made the SFO stop to gain range?
The X is nice from what I hear, but it is a bit cramped up front (although I am sure your owner couldn't care less about that for you).
Are you still looking at other types or have you settled on the X? Have you considered the Falcon 50EX?
Coming from Kallispel, MT on one trip. SFO is kind of on the way if you look at HI on a global map. Other trips seem to funnel through SFO as well usually. I have never flown SOCAL-HI or SEA-HI so I can't speak as to how well the plane would do that trip.
I am thinking SFO was the fuel stop due to range as well. SFO sticks out JUST enough to do the trip safely.
I flew HI trips from SFO as well. SFO gives you the best distance advantage and the best tracks to HI. I'm not sure how the tracks run from SEA though. Convince your flight department to buy a Global Express!! Tell them.. NOPE, the X can't do it, but the Global can!
We haven't 100% decided on a Ten, but it's a strong front runner. For reasons that are beyond the scope of this discussion, the Falcon is not an option. The G200 was in the running, but seems to have run right off the end of the runway, so here we are.
So, nobody here has flown the X from Seattle to Hawaii?
I've flown it to HI from MRY, SFO, and OAK. Seems to be a trend. Was within comfortable limits from those dept points. I did some day rate work for a company who would fly from SDL, (Scottsdale AZ) non-stop to HI. Seemed to make the guys pretty nervous, for obvious reasons. Think they're flying a DA-900 now so its no sweat. I'm guessing Seattle to HI would be pretty tight. I flew for a company that did contract work for Netjets and they had no problem making fuel stops when there was a shadow of a doubt. Maybe thats why you won't find many Netjet pilots who haven't flown out of any airport to HI from anywhere else but the bay area.
We've flown a CL30 from KSUN to Hawaii no problem. Only problem with the plane is the waiting list to get one.
You are correct sir. Oh, and also the fact that that waiting list means the price is about 1.5 mil inflated... And then there is the fabled Bombardier product support... But, I digress. The 300 is off the table for us too.
I have flown the X from SEA to PHKO for NJA a few times. Speed must be brought down to .82 - .84 so there is no wet footprint, but it will do it. At some points in the winter when the winds go much over 100 knots on the nose, you cant get there without a wet footprint, and at least at NJA, that means you dont go.
As a matter of fact, even from SFO, there is no way to go Max Cruise and have a dry footprint. If anyone says they have done it, they are ignorant to what a dry footprint is. PM me it you have any questions.
I was reading about that earlier today. Interesting stuff! Funny that they are just now getting serious about winglets for a plane that has been around for that long.
What he said.
LRC .82, Initial altitude of FL430.
The wet footprint issue in the X is due to pressurization issues. A general rule I use is if you have winds 100+ at altitude and 50 at 15k, you can make it dry but you land nearly dry (it is an emergency, so I'll consider that acceptable). That's leaving with eight pax, lots of bags, 12200lbs of fuel, 36,100lb take off. Decrease people/bags, add 800lbs of fuel and your that much better off. That is the worst case scenario that I've found in the X. You can't go out there at max cruise and not have a wet footprint though.
Can't beat it for trip times. I've make PHOG-KSBP in 3hr 50min. Personal record.
